Projects Edsel radiator
Discussion in 'The Hokey Ass Message Board' started by bedwards, Apr 19, 2020.
  1. bedwards
    bedwards
    Best place to get a new radiator for 1959 Edsel Ranger 361 V8? Toying with buying new or having mine repaired.
    much thanks
  2. town sedan
    town sedan
    There might be some interchange between your Edsel and the '58 & '59 Fords even if not mentioned in a catalog. Someone here will know for sure.
    -Dave
  3. bedwards
    bedwards
    I think Auto City Cl***ic is where I got my gas tank and they list one. I'll try them Monday.
  4. bedwards
    bedwards
    This is what they show but don't know for sure if it will fit. The measurements look right. Anyone tried the Ford radiator?
    Home >
    1957-1959 Ford / Mercury V-8 Aluminum Radiator R5759B
    Price: $199.00
    Product ID : R5759B
    Description
    This radiator works with the V8 core support (1 1/2" right upper inlet / 2" left lower outlet). New, aluminum direct bolt in radiator. Stock size with dual 1 1/8" rows of cooling tubes for high efficiency cooling. It has a built in automatic transmission cooler. This is stamped with welded construction, no epoxy.
    Fits: 1957-1959 Ford or Mercury fullsize
    Core size: 23 1/4" wide, 18" tall, 2 1/2" thick
    Overall size (widest point): 25 3/4" wide, 24 1/2" tall, 4" thick
    *Polished radiators will take an additional 2 weeks to ship.
    Spooky likes this.
  5. Spooky
    Spooky
    I saw this as well and am thinking of pulling the trigger on one.
  6. bedwards
    bedwards
    Spooky, I tried it and it didn't fit. Had to ship it back. My fan would hit the tank on the upper p***enger side relief. I ended up rebuilding mine for 150$ here in town. I have the 361 V8 if that helps any.
  7. lippy
    lippy
    from Ks
    Re building an orig radiator around here is expensive. I just had an O/T 70 Road runner one done and it was $750. Yeah probably got ripped off. Lippy
