Education, please......
Discussion in 'The Hokey Ass Message Board' started by sliderule67, Feb 12, 2006.
  1. sliderule67
    sliderule67
    from Houston
    I see a lot of references to A coupes on '32 rails. The benefits of doing this are? '32 frame is stronger? Or? Tks..........slide
  2. striper
    striper
    29's on 32 rails look better than 32's on 32 rails IMO.
    Pete
  3. Harms Way
    Harms Way
    It's mostly personal opinion,.....but first you automatically increase your wheelbase from 103" to 106", this longer wheelbase works toward a better ride, personally I don't like the look of a Model A Highboy on a A frame, and I am too tall to be comfortable to drive a Model A that is channeled. The Model A on a 32 Ford frame however gives you a great highboy look and the longer wheelbase,........... IMO
    Nuff Said
  4. Olson
    Olson
    The '32 frame rails are a work of automotive art...
    Olson
  5. squirrel
    ....and compared to gennie deuce bodies, A's are cheap
  6. I suspect that "back in the day" economics played some small part, but to what extent? There were $50 deuces, so why buy a deuce AND an 'A', just to make one car from two? BUT- if you were after V8 power, the deuce ch***is swap may have been easier than adapting everything to the 'A' rails. And hey- there's almost no better lookin' hot rod that a '29 roadster highboy on pinched deuce rails.
  7. seymour
    seymour
    from PNW
    Because chicks dig 'em like that! :D
  8. coupeHEAD
    coupeHEAD
    If you've ever seen a Model A high boy on Model A rails you'll see all the parts hanging under the car. That's why Ford put splash aprons on Model A's to hide the ugly rails and everything else under the car. 32 rails were part of the finished 1932 car, nice looking and they blended in between the fenders. The 32 rails hide most of the stuff under a Model A highboy and gives it a much cleaner look. Take a look at the Mike Bishop/Vern Tardel roadster, the sidepipes hide that ugly Model A frame.
  9. what fenders
    what fenders
    first off a model a on model a rails isn't a highboy.no way no how. the term came from bolting the body on top of the 32 ch***ie. s**** the 4 door seadan body and put on a 26 or 27 t roadster or a 28 to 31 roadster and you have an instant v-8 powered lighter weight hotrod easier than putting the v-8 in the model a frame. latter dave
  10. woody
    woody
    Consider too that the '28-'29's had a lower profile and were lighter than a '32.
    Woody
  11. 2manybillz
    2manybillz
    This is along the lines of what I heard and read in the late fifties early sixties. Early rodders would find a cheap or wrecked '32, any body style, strip off the body and put on a cheap, plentiful, Model A roadster or coupe body. Fairly "instant" V8 hot rod. (I'm not getting into the highboy argument though)
  12. Bigcheese327
    Bigcheese327
    Maybe that was true at one time, but it sure isn't anymore. The current definition of a highboy is a fenderless car that has not been channeled.
