Eelco geared throttle linkage
Discussion in 'The Hokey Ass Message Board' started by Algon, Nov 16, 2009.
  1. Algon
    Algon
    I just picked these up, anyone got a set or used them ? I was told this set is intended for two 2barrels but they would have to be back to back for this to work I'd guess like those on the 4 barrel adapters.
  2. Algon
    Algon
    This the picture I bought them off of...
    * Now having them in my hands and being only about an inch and an eighth across, it is more apparent that they have to be for the four barrel as has been pointed out. Thanks guy's...
      75.2 KB
  3. scootermcrad
    scootermcrad
  4. landseaandair
    landseaandair
    from phoenix
    That's a mechanical secondary conversion for a holley four barrel. The gear part was kind of sketchy though.
  5. Algon
    Algon
    Thanks... I got the idea from a machinist buddy and was actually looking for some sort of donor to make a similar set of gears instead of cutting something new looking. Most of my build parts are Eelco but I've never seen any of these...
  6. ND 1949 B66-465
    ND 1949 B66-465
    from Minot ND
    Kind of looks like a kit that was sold to convert a holley 4-barrel into a double pumper. you had to drill a hole in the choke housing so the long tubes would feed the secondarys.
  7. Algon
    Algon
    Do you have any of them to spare? Or remember when they came out?
  8. old beet
    old beet
    Had that "squirter kit" on a 780 cfm Holley 40 years ago!
  9. Algon
    Algon
    Makes sense, I wasn't sure if it was directly related or just grouped that way for sale... I didn't get many answers with it but really only cared about the gears and Eelco brand.
    *Thanks for the all the replies...
  10. landseaandair
    landseaandair
    from phoenix
    Nope. They pop up on ebay every once and a while and without any catalogs handy I can only guess they originally came out in the mid to late sixties.
  11. Algon
    Algon
    That's where I got these... I'll have to do some more digging but I have not found any listings yet. The script is the earlier type block letter style so I'm hoping for at least a 64-65 date. Thanks again...
  12. old beet
    old beet
    I just checked a picture of the car I had that kit on. It is dated 1967, and I know it was a well known kit then, so 64-65 should be rite.....Beet
  13. Shaggy
    Shaggy
    from Sultan, WA
    The eelco mech secondary one i have on my daily looks nothing like that, it's just a cheep piece of L shaped tin and a long bolt, nut and spacer. They are really crude and dont really act all that smooth about halfway through the 2ndarys
    As for when mine came out, ive seen photo's in a 66-67 magizine
  14. fab32
    fab32
    I also had that setup on a holley in the 60's. As reported it was sketchy at best. What someone said about it being a poor performer on the top end of the throttle travel is also correct. Just when you need an enhanced richening the most the accelerator pump was almost out of travel resulting in a leaning of the mixture. The addition of a 50cc pump would have helped with the leaning but I don't think the larger capacity pump was available at that time.
    frank
  15. Algon
    Algon
    Thanks again for all the replies... Sounds like they died out for a good reason. I still need to get these in hand to do some measuring but I would like to find another pair of gears if possible.
  16. Atwater Mike
    Atwater Mike
    Yeah, 'sketchy'. Buddy of mine ordered a new '63-1/2 Ford fastback, 427 side oiler. He sent his Holly carbs down to Les Ritchey (Performance ***ociates) for this modification.
    The carbs and distributor (improved drag race advance curve) made a notable difference, but the gears wore out the throttle shaft bushings in 3 months.
  17. Motion Performance in Long Island (Baldwin-Motion) used those kits on their "Phase III" 427 Camaros, Chevelles & Novas; especially on the big Holley 3 barrel carbs. Strictly a performance gimick and not worth a damn for everyday street driving. Worked OK at wide-open throttle (street racers loved them for some reason :D ) but WAY too rich at any cruising speed unless you're running something like 5.38 rear gears!
    Seems like Mr. Gasket also made a similar gear-drive secondary kit.
  18. Shaggy
    Shaggy
    from Sultan, WA
    I didnt think about it when i first posted, but these are for 1 to 1 operation, whereas the tin one i was talking about is normal progressive 2ndarys
    NC (mtn) dweller likes this.
  19. Algon
    Algon
    Thanks again for the replies.
    I had other plans than the intended use for these but have come up with a different approach. If anyone has interest they are now forsale or trade.... Otherwise I might try them on a 4 barrel at some point just for fun.
  20. Did u find more parts ??
    I'm getting into the 3 Barrel Holleys and I have seen those gears u had pictured installed on some !!!
    I'm actually looking for some old items to use on a 3 barrel Holley
  21. How much for parts ?
    Thanks
  22. mgtstumpy
    mgtstumpy
    Smokey Yunick did it differently with a variable intake 409463905_705152314920607_8054548350995697543_n.jpg 409442600_705152198253952_4840914669714473292_n.jpg 409047059_301213489549349_412243941026927898_n.jpg
    Dick Stevens and saltflats like this.
  23. DDDenny
    That thing makes my head hurt!
    mgtstumpy and 427 sleeper like this.
  24. Mike VV
    Mike VV
    from SoCal
    Pretty interesting actually. Lengthen the runners for corners and shorten the runners for the straights ?
    Without a computer to actually do the adjusting, sounds like a lot of work while driving, to make it...work !
    Mike
    mgtstumpy likes this.
  25. DDDenny
    It may have just been a "what if" flow bench test intake, but, if that was on a running engine, I can't get past the HIGH PROBABILITY of those gears losing a set screw!:eek:
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    They did.
    I used that kit on a drag car with two Holley 600s on a TR-1 intake on a 327 SBC.
    When I heard Mr. Gasket was sued because a spec of grit in the gears caused them to bind in a open throttle condition I went in a different direction.
    Algon likes this.
