electrial problem
Discussion in 'The Hokey Ass Message Board' started by chainsaw, Oct 5, 2013.
  1. chainsaw
    chainsaw
    I have a short that I cant track down on my 62 t bird. The airride switch is spliced into the power window wiring . I have voltage to both the power window switch and to the airride switch but neither works. If I drive for awhile, both will start working again (loose connection I cant find ?) and they both stop working at the same time. If the power window switch is bad (none of the windows work) will it still p*** voltage to the airride switch but not let it or the windows work? I cant figure why I have voltage at both switches but neither works. Thanks.
  2. 55 dude
    55 dude
    Your getting voltage but no amps.
  3. frank dog
    frank dog
    Yup, To much Amp draw. Usually, on any additional equipment they're( for exp. AirBag systems) run on their own power source. No tie in with existing components.
  4. themoose
    themoose
    I would start checking grounds...All clean and tight
  5. chainsaw
    chainsaw
    How do I get more amps? It looks like the airride is hooked into a connection on the original wiring (not sure what was disconnected to do this) When I was checking for voltage I unplugged the airride switch and the windows still didn't work. When they do work they both work with the car running or off in the acc. position. All the grounds and connections seem to be good, everything else works fine. Thanks.
  6. 40FordGuy
    40FordGuy
    Power windows are usually wired thru a self resetting circuit breaker; Adding the air ride pump is overloading that circuit, and the breaker trips. After a while, it self resets.
    Take that air ride pump off the window circuit, and give it it's own, independent electrical feed.
    4TTRUK
  7. 24riverview
    24riverview
    What 40fordguy said, the wiring diagram I have shows a relay fed from the starter relay, controlled by the ignition switch that feeds power to a 30 amp circuit breaker. I'd start checking there to see where you're losing power but I'd bet on a over worked circuit breaker myself.
  8. chainsaw
    chainsaw
    The pump is wired to a separate toggle switch and still works when the windows don't. Only the solenoids are hooked into the windows. When you drive, sometimes it starts working within 2 or 3 minutes, sometimes it takes over 30 minutes, no real pattern to it.
  9. Marcel8u
    Marcel8u
    I take it you didn't wire the air ride yourself... I would re wire the air ride system, take it off power window circuit, and fuse the new air ride circuit.
  10. M224SPEED
    M224SPEED
    from Missouri
    I agree 100% with what some of the guys said,rewire that air ride connection to a relay all on a seperate circuit for the air ride ONLY.
    Also take a good look at the present wiring and grounds for those power windows as I am sure they have been overloaded !!
  11. handyandy289
    handyandy289
    from Georgia
    Ground. Connect a temporary ground to the pump and see if that corrects the problem.
  12. indyjps
    indyjps
    If the window circuit is on a self resetting relay, the alternator kicking on may alow it to rest, this gives you the random situation you have, move the airride to its own circuit
  13. chainsaw
    chainsaw
    Thanks guys , I'm going to rewire it today as suggested.
  14. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Really clean ground connections make life easier!
  15. chainsaw
    chainsaw
    Ok, I just rewired the airride straight to the acc. position on the fuse box. Airride works again but still no power windows. Ill look into that latter.
  16. 325w
    325w
    On later model cars sometimes the wire in the door jamb breaks down. Normally from being opened and closed so much. Jus a thought.
  17. chainsaw
    chainsaw
    You nailed it . The 30 amp circuit breaker is bad. took off the two wires and jumped them together and the windows work again. Just have to order a new circurt breaker and I should be good to go. Thanks again for everyones help.
