Technical Electric AC Compressor
Discussion in 'Traditional Hot Rods' started by knuckle44, Apr 4, 2019.
  1. knuckle44
    knuckle44
    wish to have air conditioning in my ‘47 Ford PU street rod but no room for a belt driven compressor. Sean Hyland offers an electric compressor but I haven’t found any reviews. Any one have experience with a Sean Hyland electric ac compressor
    Thanks
  2. Late model Hybrids have them too
    TrailerTrashToo likes this.
  3. TrailerTrashToo
    TrailerTrashToo
  4. flatford39
    flatford39
    4008 BTU/Hr is a third of a ton. Probably plenty for a small cars cabin. Power requirements are gig to be substantial to run that thing.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Requires nearly 32 amps to run probably double that on startup.
    At night with lights on and AC running you would have quite a draw on your charging system!
    KK
    46international likes this.
  6. Right, The compressor, condenser fan and the cabin fan plus the lights, it does start to add up.
  7. Ebbsspeed
    Ebbsspeed
    What you gain in space by having an electric compressor you;ll probably lose because of the huge alternator you'll need. Do you have any underhood photos you can post? Surely there's somewhere under there to tuck a compressor. Some of those small rigs like a Suzuki Samurai of Geo Metro have pretty tiny compressors in them.
  8. blowby
    blowby
    from Nicasio Ca
  9. bonzo-1
    bonzo-1
    100 plus amp alternators are easy to come by. Most newer cars have them.
  10. Ebbsspeed
    Ebbsspeed
    He did say street rod, so this is a possibility.
    Texas Webb likes this.
  11. Aren't some roof mounted camper a\c units 12v? Maybe the compressor from of those could be repurposed. If so one should be easy to obtain.
  12. The 'Walmart People' solution.... LOL
    They are right about one thing; you will need a BIG alternator (I wouldn't get anything smaller than a 100 amp unit) and while those aren't much larger than a 'conventional' alternator, you will have to do some serious upgrading of your wiring harness.
    All the camper/MH units I've seen are 120 volt using 'shore power'...
    xsquiden and scotty t like this.
