electric air conditioner compressor?
Discussion in 'The Hokey Ass Message Board' started by lorolr, Jun 4, 2008.
  1. lorolr
    lorolr
    I am wondering if anyone has any ideas about how to put A/C on a vehicle without having a compressor running off the engine. What about an electric compressor? What about an electric motor running a compressor? What about mounting the compressor under the cab running off the driveshaft? Any ideas/ experience appreciated.
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    paint it black and mount it down low on the engine.
    You could go electric if you used a small 110 home unit and a LARGE inverter. And batteries to run the inverter
  3. Retrorod
    Retrorod
    The new GM hybrids use a non-belt driven electric compressor but I bet it would be pretty costly to attempt. Open the windows......drive 60 mph.
  4. M_S
    M_S
    from SoCal
    Running it off the driveshaft would not be a good idea in stop and go traffic.
  5. BangerMatt
    BangerMatt
  6. Robert gilbert
    Robert gilbert
    from boston
    They sell none belt compresser a/c units . There was one on c l the other day. I cant find who makes them or sells on the net
  7. last.brunneng
    last.brunneng
    I've been considering something similar, both electric driven and driven by a belt at one of the wheels. I thought a modern blower motor might handle it, but I decided running it off the wheels (or the driveshaft) would make it too inconsistent. I'm definately with you in wanting to keep the engine compartment clean.
  8. KCTA Chris
    KCTA Chris
    I've wondered about this too, I had a weird idea once:
    What if I ran a high output alt or gen. Mounted one of those RV a/c converters behind the seat and ran a small (very small) portable home air cond unit back there. They are so small, cheap and dont take to much amps, plus easy to remove or modify controlls too.
    Then I realized I spend too much time reading MAKE magazine.
    And opened the cowl vent.
    But could it work?
    C.
  9. This has been hashed out before. Mark IV underdash units have been around since at least the early 60s, maybe the 50s; I plan to get a 50s or 60s A/C compressor to power mine, and let them sweat through their clothes while they make fun of me for having A/C.
  10. duste01
    duste01
    Might try an rv shop and see what they have too.
  11. kustombypook
    kustombypook
    What?
  12. RopeSeals???
    RopeSeals???
    It's not impossible, there are aircraft A/C units that are driven by electric or hydraulic motors...
  13. dusty
    dusty
    Check out the electric car builders forums. They all use electric motors driving the compressors either by direct coupling or belt driven methods. I am considering it also just not that far along in the build. Good luck.
    dusty
  14. sdluck
    sdluck
    Look for a crashed Hybrid .Some have electric A/c compressors.
  15. Road Toad
    Road Toad
    Some of the A/C compressors on Hybrids require 200V or more.
  16. No way a modern blower motor has the balls to turn an ac compressor.
  17. sdluck
    sdluck
    What about running one off the flywheel or back of motor. Make a pulley to go on back of flywheel or a toothdrive clutch
  18. Robert gilbert
    Robert gilbert
    from boston
    What i mean is i cant find the company that sells them , The eletric ac pumps . But I did see one on C L the other day . Do you get it
  19. lorolr
    lorolr
    Thanks for the ideas. I will have A/C one way or another.
  20. Plymouth
    Plymouth
    Owning a 40 p10 Plymouth , I,m considering a swamp cooler the kind you keep in the car on the floor add ice water and enjoy the ride!... Really don't want the one that hangs on the window.. but some do..
  21. Yep, lots of airplanes do. I fly used to fly a King Air that did and the one I fly now has an aux unit in the back that is electric. Our Citation is electric too.
  22. 52RustRocket
    52RustRocket
    Try this, you could kill two birds with one stone.
  23. Roadsir
    Roadsir
    I am involved in a project at work to supply a major automotive component supplier with servo motors and drives to be integrated into A/C compressors. Very compact, neat package.
    Automotive and other vehicle manufacturers are driving more and more ancillary equipment with electric motors.
    So you probably could hide the compressor, but now your alternator will be need to be the size of a coffee can!
  24. RooDog
    RooDog
