Technical Electric door will not open
Discussion in 'The Hokey Ass Message Board' started by Lowcab1936, Aug 15, 2015.
  1. Hopefully he didn't have some BS first cl*** way of mounting the window you cut. Praying that its an easy peasy in and out with no further damage.
  2. HOTRODPRIMER
    HOTRODPRIMER
    The members of the Hamb are always willing to help but the members also like to joke around.
    HRP
    Model T1 likes this.
  3. Model T1
    Model T1
    Not me. I'm always serious!
    HOTRODPRIMER likes this.
  4. tb33anda3rd
    tb33anda3rd
    a smart *** reply? or a helpful bump to the top?
    wooden floor boards? a long shot but if they are not screwed down you, or basketball player friend, might be able to reach the door handle.
  5. Davyj
    Davyj
    My coupe has a hidden cable pull which opens the trunk, to access the battery. and a hidden cable pull in the trunk can open the door, in case it is a remote issue. I have also seen people put in a back up switch in parallel with the power window switch, which can lower the window............
  6. oj
    oj
    When I do the exotics with all the electronics I get enough channels to put at least the drivers window on the fob and battery charge posts underneath.
  7. Couldn't pop the hinge pins out?
  8. bonzo-1
    bonzo-1
    I have a starter solenoid on the drivers door bearclaw with remote keyfob to open it. Inside latches work and a hidden ****on on the firewall to lower p***enger side window in case of a failure.
