Hot Rods Electric fan bad??
Discussion in 'The Hokey Ass Message Board' started by MWWADE, Dec 15, 2022.
  1. MWWADE
    MWWADE
    Finished installation of my new aluminum radiator on my 40 Olds cp. one of the last parts to bolt back on was the electric fan. After a quick check over, everything looked good with no visible leaks. So I took the coupe out for a test drive. The outside temperature was in the 40’s, and by the time I got back to my shop the car was overheating. I raised the hood, and first thing I noticed was the fan was not turning. I checked my fuses, they were good. So I pulled the wire fro the sending unit, and connected the two terminals together. I could hear the relay clicking, and the fan was wanting to turn, but would not. I then tuned the blade by hand, and it moved freely. Then it came to me, maybe the 4 fan housing bolts that secure the fan housing to the fan shroud were too tight. I loosened the bolts, and the fan started working. I guess when I tightened the bolts it put the motor in somewhat of a bind just enough to not let it turn. Thought I should share, just encase this happens to someone else.
    Dave Mc and down-the-road like this.
  2. lostone
    lostone
    from kansas
    Glad u figured it out.
