Technical electric fan mount 32 radiator
Discussion in 'The Hokey Ass Message Board' started by Wesley Laster, Jun 15, 2020.
  1. Wesley Laster
    Wesley Laster
    wasn't sure what I was going to do , so I ended up doing this for now, I may revisit it and make a whole shroud...
    All I used was some s**** flat bar I had laying around.. 3/4"x 1/8" and 1" x 1/8" thick.. All those other fan install kits use the push through round zip ties .... ( Horrible!!)
    The mount only took me 2hrs or so ...
    Right or wrong , this is what i did 20200613_093348.jpg 20200613_131505.jpg 20200613_131500.jpg 20200613_093506.jpg 20200613_143831.jpg 20200613_093524.jpg 20200613_143848.jpg 20200613_163007.jpg 20200613_165913.jpg 20200614_231836.jpg
    olscrounger likes this.
  2. AldeanFan
    AldeanFan
    Looks nice but you will get much better cooling with a shroud, as you have it now any areas not covered by the fan will not be cooled by the fan.
    Wesley Laster likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    The engine looks good, it also looks like you had enough room for a mechanical fan. HRP
    Tman and Wesley Laster like this.
  4. goldmountain
    goldmountain
    I like your cantilever vise mount and the swingaway stool.
    Atwater Mike and Wesley Laster like this.
  5. Wesley Laster
    Wesley Laster
    Yeah , I know ... ill be making a shroud in the near future..
  6. Wesley Laster
    Wesley Laster
    I do ! And I have the fan to go on it ... i just thought I'd see how this is first ... i had this electric fan laying around from a previous project, so I thought I'd put it to some use
  7. That needs a shroud and a mechnical fan.
  8. Wesley Laster
    Wesley Laster
    Vice , grinder , planishing hammer , and some other tools , are all made to slide in tow hitch tubing I welded to bottom of the table .... makes it nice ..... 20200518_185230.jpg 20200510_200517.jpg
  9. Thats a nice bench
  10. Wesley Laster
    Wesley Laster
    Thanks !! Still not done .. need to add sliding door on the one side ill be hanging all my hammers on it .
    Here's the other side.
    The bottle jack lift makes it a snap to move around... seeing how my shop is only 16'x30' 20200515_045205.jpg 20200515_045218.jpg
  11. Atwater Mike
    Atwater Mike
    Well thought out. Bottle jack on descending casters...WAY better than the old foot drop casters!
    This bench is inspiring, as I'm limited to 25' X 25'. Too many projects to waste space here. Very commendable. Thanks.
  12. wheeldog57
    wheeldog57
    "Right or wrong this is what I did"
    Man, this sounds like me!!!
    All joking aside, the fan mount looks perfect.
    Well done sir
  13. HOTRODPRIMER
    HOTRODPRIMER
    If you decide to go that way in the future you might consider using a zips riser, it will move the water pump up 5" and that will center the fan on the radiator. HRP
  14. Wesley Laster
    Wesley Laster
    I think I've seen those , pretty kool
  15. If you do a search on here there are some great threads talking about the Zips and Snow White risers
  16. HOTRODPRIMER
    HOTRODPRIMER
    This image gives you a idea of how the zips looks installed. HRP
