Technical Electric fan relay keeps blowing
Discussion in 'Traditional Hot Rods' started by airbrushguy, Sep 11, 2025.
  1. airbrushguy
    airbrushguy
    from NJ
    My ‘49 Hudson with a 500 Caddy engine keeps blowing the fan relay.
    Only driving in backyard on and off the lift
    Any ideas why it would ?
  2. Budget36
    Budget36
    Is the coil/solenoid opening up or is it the contacts going bad?
  3. Joe H
    Joe H
    How big is the wire going to the fan and from battery? How long are the wires?
  4. Happydaze
    Happydaze
    What's the rating of the relay?
    Chris
    1971BB427 likes this.
  5. Ziggster
    Ziggster
    Does current rating of the relay match that of current draw of the fan(s)? Is there more than one fan running off of the relay? If so, how is it wired up? DC motors typically have an in-rush current that is greater than the max stated current draw, but typically this is not an issue as the in-rush current is momentary.
    Is the orientation of the relay specific (e.g. some relays need to be mounted “upright”)?
  6. 19Eddy30
    19Eddy30
    from VA
    Check amp rating of Fan ,
    Correct wiring size Ga for Length of wire ,
    My Spal fan pules close to 50a
    Typical bosh relays are 15 amp
    & 30
    Bigger amp relay have 1/4 inch spade Terminals or screws
    ekimneirbo and Just Gary like this.
  7. mike in tucson
    mike in tucson
    from Tucson
    Ziggster hit it.... some Cooling Components fans draw 60amps on startup.... those 15a contacts dont like the draw.
  8. Jalopy Joker
    Jalopy Joker
    so, not blowing hard enough to keep things cool?
    Bentrodder and Ziggster like this.
  9. Mr48chev
    The guys hit it spot on in that the amp load of the fan is more than the relay is related for and or more than the gauge of the wire can handle.
    There are hundreds of wire gauge vs amps charts on the net and I don't think any two that weren't copied from each other are exactly the same. Screenshot (705).png
    vtx1800 likes this.
  10. 57 Fargo
    57 Fargo
    First question is how is the relay "blowing" how exactly is it failing?
    this relay handles high amp startup rush, also has a diode built in to avoid engine run on due to the fans producing electricity. I've used it on several builds.
    vtx1800 and MARKDTN like this.
  12. RodStRace
    RodStRace
    These fine fellas have got the basics covered. An electrical circuit that 'blows' is not sized properly or shorted.
    I have to ask how it's set up also, along with the other questions. If it's thermostatically controlled, how is it even engaged
    It shouldn't get hot enough to trigger. If it's a switch you control, it wouldn't need to be driven or even running.
    Can you describe the whole circuit?
    Power input to relay
    Power output from relay to fan
    Relay
    Fan
    Trigger and ground
    How fan is grounded.
    Algoma56 and firstinsteele like this.
  13. Mike Goble
    Mike Goble
    For my cars with electric fans, I use a Volvo 2-speed fan control relay. It is specifically designed for controlling an engine cooling fan. It has large copper contacts and even works well with a single speed fan.
  14. @Mike Goble , do you have a part number, reference id, for that?
  15. RodStRace
    RodStRace
  16. LOL! FIRST TIME THAT HAS EVERHAPPENED! Not.:D:D
    Ben
    RICH B, RodStRace and 19Eddy30 like this.
  17. G-son
    G-son
    from Sweden
    Well... He may have been back to read, without logging in.
  18. gene-koning
    gene-koning
    Maybe he found the spot on the wires between the relay and the fan where the insulation was cut or melted through, and the wires were grounding out.
    Algoma56 likes this.
  19. pprather
    pprather
    Big Al likes this.
  20. Mike Goble
    Mike Goble
    The two part numbers I have are 3523872 and 94432933. I get them out of 90's Volvos at my local Pick and Pull. I also take the mating connectors and as much wiring as I can. I have about half a dozen of them and they are easily available on Ebay or AutohausAZ. Here's a wiring diagram as well. For the temperature switch I use a BMW dual 91/99C unit.
    Algoma56 and RodStRace like this.
  21. wheeltramp brian
    wheeltramp brian
    In the diagram, it looks like you have to use The volvo sending unit Also, is that correct?
  22. Mike Goble
    Mike Goble
    You can use any Normally Open temperature switch because it's the grounding of the wire that triggers the relay. You can use a single temperature switch and run your single speed fan just fine.
    I have a 2-speed fan, so I use a dual switch. You can use a manual switch to byp*** the temperature switch.
    If you google Volvo fan relay you will be linked to several videos on how different people installed these relays.
    Here's the schematic of the internal wiring of the relay showing how it works.
    RodStRace and Algoma56 like this.
