1952-59 Ford Electric fan switch
Discussion in 'Off Topic Hot Rods & Customs' started by buymeamerc, Jan 5, 2019.
  1. buymeamerc
    buymeamerc
    from s.c.,usa
    where are you guys putting your electric fan switch(controller)?
    54 mercury y block
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. fordsbyjay
    fordsbyjay
    from Lafayette
    I put mine right next to the radiator.
    That mess on the far side.
  4. fordsbyjay
    fordsbyjay
    from Lafayette
    Here is a better picture. I used some 1/8" aluminum and made a plate to mount the controller and relays to. I used circuit breakers instead of fuses.
  5. Texas57
    Texas57
    Mine required a 70 amp relay kit, which I got from Ron Francis. It had to be tied to the trinary switch on the AC. My trinary switch is on the AC drier (in engine compartment), but I installed the relay under the dash. Keeps the engine compartment a little cleaner, and keeps all the connections out of the weather.
    fordsbyjay likes this.
  6. Texas57
    Texas57
    Hopefully I can patch in a pic of the above mentioned A/C relay and fuse. That is the Ron Francis Express wiring panel on the left kickpanel, btw. Made for my car, it has a serial number on it registered in my name.[​IMG]
    BruceMc and fordsbyjay like this.
