electric fan ??
Discussion in 'The Hokey Ass Message Board' started by pkj, Jan 18, 2009.
  1. pkj
    pkj
    I hope I can get a little help here. I bought a electric fan from a hot rod parts vendor at the Moultrie swap a year back. Guy told me it was the best one and he sold a lot. It was smaller then I thought was needed, but he still felt with a good shroud it was the best for the money. I think I paid about 60 bucks. The only markings on the box are " TBI 14 " it is 14 inch and 10 blade. Very slim blades. The plug has 4 prongs, two will power the fan, and if I reverse them they change the direction. Does anyone know how to tell what is the intended way this fan should work, push or pull? If I remember (yea right) he said there was not much differance. I have a 400 sbc punched .040, so I want to get the most cooling I can. I have room to build a shroud on either side of the rad, but would really like to set it up as a puller on the backside. On my set up it will be a lot less visible. Mechanicle fan is not an option on my set up. There are no markings on the fan itself, but it was a sealed box. Hope you guys can give a little help here. Thanks, pkj
  2. It will work best as a puller fan, installed between the engine and the radiator.---Brian
  3. sun down
    sun down
    from tx
    darn, you beat me to it...........seems like most feel puller are more efficient..
  4. 325w
    325w
    Most fans can be converted to pusher. My bet is it is already a puller. Plug the fan up watch your fingers and see which way it works best. You will feel a difference in pushing than pulling in the air flow. If you see it is a pusher try taking the blade off and turning it over. $0.02
  5. pkj
    pkj
    thanks for the replys. i will now change my name to dumb ***. i went out and did a check and it pulls a lot more then pushes. sorry to waste space and time...dumb ***
  6. hotrod-Linkin
    hotrod-Linkin
    good advice guys.most pushers are restrictive with the air having to cross over the blade . i am sold on the puller function fans.
    not trying to turn this into a puller-pusher war..just my preference.
