Electric fans are ugly......tech.
Discussion in 'The Hokey Ass Message Board' started by Bobby Green, Feb 13, 2007.
  1. fab32
    fab32
    Reason no. 35,759 why the HAMB is so cool.:cool: :D Well done!!
    Frank
  2. custom61
    custom61
    awesome..... im gonna have to remember this one!!!
  3. haring
    haring
    Great idea!
    I collect old fans. I'm still able to find them dirt cheap.
    I just GAVE AWAY an old GE 24" industrial fan because it didn't work, I didn't have the time to fix it, and it was heavy as hell (probably 100+ lbs). I should have stripped it for it's cage and made a lamp out of it. :)
    Old appliances are great for cannabalizing. Strip out motors, gears, drums, switches, etc and you'll find a re-use for something.
  4. chuckspeed
    chuckspeed
    did a quickie search on Grainger...
    A standard 16" industrial man-cooling fan ($80.00 list) can get the same 'look' without ripping apart a vintage fan. It might even be worthwhile to see if the fan blades can't be hung on the 12V shaft and hard mount the 12V motor in the shroud - this would eliminate all the plasticky stuff - use a stainless steel bowl to hide the 'modern' 12V motor...
  5. Retrorod
    Retrorod
    We wanted to have our cake and eat it too, Flower said we need it to run cool but we HAD to keep the original fan. So we did it this way and Flower learned how to set rivets at the same time.
  6. Perforate the bowl so the motor doesn't overheat.
  7. MarkX
    MarkX
    from ...TX
    or you could go to you local discount store or hardware store and buy a replacement round bbq grill and bend the outside edge in.
  8. atch
    atch
    s.s. colander?
  9. fatty mcguire
    fatty mcguire
    some where they do have a fix for radial tires, my friend got radials for his 55 g***er that look like bias. I think what they do is recap a radial with a bias ply tread. They are expensive but they looks really good
  10. Django
    Django
    from Chicago
    Pure genius!
  11. Django
    Django
    from Chicago
    pure genius!
  12. pitman
    pitman
  13. hotrodladycrusr
    hotrodladycrusr
    Very cool idea! Thanks for sharing.
  14. Roothawg
    Roothawg
    I'm buying up all the vintage electric fans I can buy.....I'm gonna be the fanlord. They're the next E&J fad.
  15. DeuceDog
    DeuceDog
    from Breese, IL
    Great idea...not to hi-jack but, has onyone put a small fan between the grill shell and the insert on a 32? I have a mech. fan on a SBC but it does get hot in traffic.
    Again great looking modification.
    DD
  16. Jeem
    Jeem
    Alliance Vendor
    This idea totally blows.
    theHIGHLANDER likes this.
  17. Offy
    Offy
    A flat black shallow electric fan on a flat black radiator is pretty much camouflaged, IMHO. The shinney old fan guard brings attention to it. Run one off the water pump and be real.
  18. Slide
    Slide
    I think it ****s.:D
  19. Evel
    Evel
    Rat-Rod-Erific!!!
  20. That looks perfect, guess vintage fans are now on my garage sale and swap meet list.
  21. If you cant use the real thing, then this is tops! well done looks great.
  22. Shifty Shifterton
    Shifty Shifterton
    Great idea!
    a couple to add-
    A person could remove 80% of the plastic finger guard on the electric fan to make it look less modern. You've got a fancy new metal finger guard, right?
    Combine the cut-away plastic finger guard with an electric fan that uses a traditional blade instead of the swept blade shown here, and it would look really old timey.
    Cool idea for sure. Keep up the good work.
  23. Wasahawaiianrat
    Wasahawaiianrat
  24. graverobber63
    graverobber63
    Alliance Vendor
    thats the coolest original idea I've seen in a while. Viva la Hamb
  25. Bobby Green
    Bobby Green
    If I could run a real fan off the water pump I would, but as you can plainly see in this photo, the fan would have to be about 5 inches in diameter and totally flat.
    Now, I just threw this together in one day from stuff I had layin around the garage. I didn't kill a nice fan either, the grill came off an old 50's propane heater that didn't work anyway, so don't cry.
    But if I had the time and the room, I would probably use a fan like this one. That way you can cover the sides of the plastic fan, and completely enclose it. You would have the cut it down, but if you also act as a shroud.
  26. very cool idea if you have to use an electric fan.. thanks for sharing.
  27. OUTSTANDING! Where'd you get the centerpiece?
  28. Appleseed
    Appleseed
    Uh... I'm getting a "bandwidth exceed" icon. I can't think without pictures. Kidding, I get the gist of it without see em.
  29. swaybelly321
    swaybelly321
    Same here on the pics, damn, hopefully I can catch them later as i'll probably need to run an electric to help cool.
    Stevo
  30. Bobby Green
    Bobby Green
    Are the pics back up ?
