Technical Electric Fuel Pump/ Flathead
Discussion in 'The Hokey Ass Message Board' started by Richard Reed, Jul 29, 2019.
  1. Richard Reed
    Richard Reed
    from Maine
    I am looking for an electric low volume fuel pump on my AV8 with (2) Stromburg 97s. The Vern Tardel Highboy project recommended a Walbro wep-38 Pt# 2403. I tried one company online but they never returned my calls. Haven`t found anyone else. I will be frame mounting whatever I find. I suppose I can put a re-stricter on the output if I had to but prefer not to. Any leads will be helpful. Thank you.
  2. weathrmn
    weathrmn
    I used an Airtex 12v electric pump, I don't have the part number,I looked it up at our local parts store.
    The pump is rated at 4 psi, round body w/clamp.
    I use 5/16" steel tube to a holley regulator set @ 3 psi., 1/4" hose
    from the regulator to 2 holley 94's, 40 Ford with a 50 Mercury engine
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Probably this one ? https://www.summitracing.com/parts/atx-e8251
  4. Aaron D.
    Aaron D.
  5. Mimilan
    Mimilan
  6. Helge71
    Helge71
    I have a quite similar setup (2 Ford 94s instead of Strombergs) and am very satisfied with the Pierburg type E1F, No.7.21440.51.0 in line fuel pump (after the previously used Holley didn't last very long...) The pump has a static pressure of about 4 - 5 PSI and is designed for system pressure of about 1,5 PSI. It is so far very reliable and realtively quiet... Maximum volume is 95 l (~25 gal) per hour.
  7. choppedtudor
    choppedtudor
    I'm running an electric pump for a VW...a Holley regulator...and a 0-10 psi fuel pressure gauge.
