Technical electric fuel pump
Discussion in 'Traditional Customs' started by lucky bob, Feb 2, 2017.
Tags:
  1. lucky bob
    lucky bob
    I have a holley 12-802-1 fuel pump located inside engine compartment on fender well. I ran it out of gas and it has not been the same fuel strav when on an incline sometimes makes a loud noise sometimes I think I need a pump that will pull and push any thoughts
    henryj1951 likes this.
  2. squirrel
    That pump needs to go back near the tank....
  3. jimmy six
    jimmy six
    It's a pusher not a puller...
  4. lucky bob
    lucky bob
    i just got this car and would like to keep from having to relocate the pump if possible it is a 69 mach 1 351 cl 4-b carb do they make a pump that would work in the current location
    thanks
    bob
  5. squirrel
    kind of off topic for this forum...
    but the stock mechanical pump would work, eh? that's what I would use.
    falcongeorge likes this.
  6. wraymen
    wraymen
    The mechanical one that came with it originally.
  7. bob...you are probably not going to be lucky to find an electric pump like that
  8. falcongeorge
    falcongeorge
    from BC
    this is cl***ic HAMB. Install the pump wrong, and when it fails blame the pump. If you want the pump up front, run a mechanical pump, full stop, end of sentence.
    henryj1951 and Texas Webb like this.
  9. lucky bob
    lucky bob
    im sorry this is my first day on this web site ill find a garage that may have an idea on how to leave it where it is they really did a nice job with the engine detail and it will be a pain to have to re run all the lines and all thanks though to all you guys for the help sorry for being off topic
    bob
    henryj1951 and firstinsteele like this.
  10. fine, leave the pump where it is for looks ...and then put an electric pump back by the fuel tank. it will push through the front one.
    sounds crazy, but should work fine
    you do know that making changes and fixing things are part of hot rodding? not everything has a quick and easy fix...or maybe i'm wrong and there is a smart phone app for this?
  11. henryj1951
    henryj1951
    from USA
    as the good guys have already said, but with one caveat,
    they also like the fuel above them to keep them wet.
    so mount her down low
    Well thats what she said... shave -n- a haircut 10cents
  12. lucky bob
    lucky bob
    i know i was trying to save a little money on a fix for a problem due to a poor location
    thanks for all the help keep em running
    bob
  13. falcongeorge
    falcongeorge
    from BC
    exactly. Any electric pump that does not have "head" on the inlet WILL fail.If you run an electric pump dry, it will also fail. The OP's pump is already on the way out from when he ran the tank dry, that why its noisier now.
    Bandit Billy and henryj1951 like this.
  14. seb fontana
    seb fontana
    from ct
  15. tb33anda3rd
    tb33anda3rd
    it is possible that you may have pulled some ****/rust off of the bottom of the tank when it ran out. very common. the line could be partially plugged, the pump screen could be plugged or the the inline filter [if it has one] or the filter in the carb. check those, then try it.
  16. RmK57
    RmK57
    Not sure what's done to your Cleveland but they have mechanical pumps that can easily support 500hp.
  17. c-10 simplex
    c-10 simplex
    Yes; This is the pump i use:
    http://www.facet-purolator.com/dura-lift-pumps.php
    The can push as well as pull (which i guess is called "lift" in fuel delivery terms?)
    And the reason i use it is because i'm running one the "newer"/"vortec" SBC blocks, and these blocks are not drilled to accept a mechanical fuel pump and/or fuel pump pushrod. i would have much preferred to run a mechanical pump. (As in interesting side note, the cam that came with the engine still has the lobe to run the fuel pump pushrod, though.....)
    And, as with many others here, i was baffled as to why you wouldn't run a mechanical either, but you seemed to have answered that already.
    But this elec pump has worked great so far. i have a little over 5000 miles on it.
  18. Beanscoot
    Beanscoot
    "not everything has a quick and easy fix..."
    ... but this one does! As has been said, the wrong pump application was used. The original mechanical fuel pump is cheap, readily available and will work great.
