1952-59 Ford Electric Fuel Pump
Discussion in 'Off Topic Hot Rods & Customs' started by Nalakaya, Mar 12, 2020.
Tags:
  1. Nalakaya
    Nalakaya
    I want to put AC in my 56 and would like to go with a serpentine pulley set up on my 351W because it is a cleaner look. Unfortunately, the set up I like I can't run a mechanical fuel pump.
    My 351w is stroked to a 427 and I'm running a carb. I need a minimum of 50 gph pump. I really don't want to go with an in the tank fuel pump yet.
    I know this has been ask before, but I wanted some current reviews.
    What electric fuel pump would you guys recommend? I'd like it to be somewhat quiet but mostly reliable since I drive to allot of shows.
  2. okiedokie
    okiedokie
    from Ok
    I have used a Carter P4070 on my 53F100 for several years with out a problem. Also used one on a previous car. Very pleased with the product. I believe they flow 72GPH. I had used some others previously with several failures then a friend turned me on to the Carter.
    Are you going with a factory serpentine or aftermarket?
  3. Nalakaya
    Nalakaya
    I see many have been having good luck with the carter so I think that is the way I'm going to go.
    I was looking aftermarket. Either the Vintage Air Front Runner or the Billet Specialties. They are not cheap so I may investigate the factory set up. I have a CVF 2 belt pulley set up on the motor now which I like and it would be reasonable to just buy the brackets for the AC compressor but it sets up off of the motor and looks ugly.
    Thanks for the input.
  4. okiedokie
    okiedokie
    from Ok
    I have the factory 302 serpentine setup on both my 53F100 and my 55 Sunliner, pleased with them.
  5. 50sboy
    50sboy
    I use the carter - and be sure to use rubber isolator mounts and you wont even hear it!
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    https://www.jalopyjournal.com/forum/threads/does-anybody-make-a-quiet-elec-fuel-pump.440703/page-3 (I used the Carter P4594) This thread has some ways to quiet the pumps.
  7. Nalakaya
    Nalakaya
    I will probably need the carter P4594 since my carb needs around 6.5 psi.
    Thanks for the replys.
