Technical Electric Fuel Pump
Discussion in 'Traditional Customs' started by George Hamilton, Jan 23, 2025.
  1. George Hamilton
    George Hamilton
    No, mechanical is removed.
  2. 57JoeFoMoPar
    57JoeFoMoPar
    I'm sure what you did was fine. 5 or 6 inches of space is more than adequate. Just make sure your hard lines are flared so the rubber doesn't pop off under pressure. Don't over think it. You'll be fine.
    squirrel likes this.
  3. jimmy six
    jimmy six
    IMO Ford Y’s don’t need an electric pump. I been using the stock mechanical or the 13 years I’ve owned mine with a a 292 and for the last 7 years it’s had dual WCFB quads. The only rubber fuel line is the stock 5/16” from the frame to the pump; I changed it from what was there to a replacement ethanol compatible from Danchuk for a 57 Chevrolet. If my car sits longer than 3 weeks I must crank it 15-20 seconds then pump the foot feed 3-4 times and it starts right up. Normal weekend is one pump.
  4. UH OH! I didn't flare mine! 12 years ago. Am I just lucky?;)
    Ben
  5. squirrel
    yeah, you've been lucky. I've had one pop off, it's pretty darn scary to have an engine bay covered with a film of gasoline! Now I make sure there's a flare or bubble or something to keep the hose coming off when the clamp relaxes.
    mario711 and TrailerTrashToo like this.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    I look at things like this in the context of even though the likelihood of failure is very low, the possible outcome if a failure occurs is so lousy that it makes it worthwhile to take a nominal amount of time to take a preventative measure to lower the risk even more.
    99 times out of 100 nothing will probably happen. But if the 1 time it does my cars burns to the ground, then it's worth the 2 mins to flare the line or use a barb.
  7. George Hamilton
    George Hamilton
    It's gonna get done as soon as spring is here. Minesota's petty cold right now and garage isn't heated. Car is put away for the winter.
    osage orange likes this.
  8. 05snopro440
    05snopro440
    You're exactly right. I hear this excuse all the time when products are misused. "It never caused a problem in the past." No, it didn't, until it did.
