electric fuel pumps??
Discussion in 'The Hokey Ass Message Board' started by ohiohotrods, Aug 7, 2013.
  1. ohiohotrods
    ohiohotrods
    whats a good QUIET electric fuel pump I can run on a 40 ford - I will be mounting it between the tank and the rear spring mount crossmember. I got a holley blue that I tried and it has corrected my initial problem but I believe it is too noisy. any help??? or opinions?? thanks
  2. stimpy
    stimpy
    any type of gearrotor pump should be quiet like a mallory , a vane pump is always is going to be noisy .
  3. DOUBLEZO
    DOUBLEZO
    from SACramento
    I run this one from napa. No problems in the last two years. Also very quiet.
  4. Jalopy Joker
    Jalopy Joker
    also, use a piece of rubber to place between pump & frame
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've pretty much used Holleys over the years and some of them are noisier than others........one I had sounded like an air compressor. Now I run Carter electric pumps and love them. You can buy one that has a low pressure rating and it is very quiet, I have to listen closely to know it is running.
    Don
    Here is the one I am running:
    http://www.summitracing.com/parts/crt-p4602rv
  6. 87Heaven
    87Heaven
    I have the same problem as ohiohotrods.
    40 Ford on my second pump, first one was loud then it went out.
    Second has high output but really loud.
    Looking at the Summit catalog last night seems like 3 to 4 hundred dollars will get you a quite pump!
    Is that the answer?
  7. hotrod40coupe
    hotrod40coupe
    Edelbrock Quiet-Flo Electric Fuel Pump.
  8. Vandy
    Vandy
    from L.A. Ca
    I use the round one that AutoZone sells, it comes in two pressure ratings, has a filter & a rubber wrapped mounting bracket. Around $40 if I remember right. I have one on my daily driver (3 years) no issues. It's quiet, or at least I think it's quiet.
  9. gimpyshotrods
    gimpyshotrods
  10. black 62
    black 62
    from arkansas
    pumps that require a regulator are usually not needed on cars running 12.50 or slower in the quarter---i have been running a small cheapy for several years now,i put it in while waiting for a kit for a blue and never found a need to replace it---i use a separate fuel supply for nitrous with a blue pump , but it is not needed for 12 second passes...
  11. Pa G.
    Pa G.
    from CT
    Anyone have any experience with the Carter P74029 in a deadhead (no return line situation)? I'm thinking of using one with on a fairly mild 283 with a rochester 4G. Since it maxes out at 5.5 psi., I don't think a regulator should be necessary. Sounds like my situation is similar to the OP's.
  12. slatetar
    slatetar
    from london
    I run this one from napa.[​IMG]
  13. LOW LID DUDE
    LOW LID DUDE
    from Colorado
    I bought the red Holly piece of shit $130.00 Makes so much noise I can hear it over my loud roadster headers .Even mounted in rubber pad ,still is loud. I would never buy one of these again.
