Technical Electric Fuel Stop
Discussion in 'The Hokey Ass Message Board' started by desotot, May 15, 2017.
  1. desotot
    desotot
    So I have a problem with a model A I recently acquired. The fuel tank is upright behind the rear seat in a 31 Tudor with a mild rake. I noticed that the fuel is gravity feeding to the carb when it is parked. The electric fuel pump doesn't hold back the fuel so if the carb leaks it fills up the crank case with gasoline. (blown power valve on a holley.) Is there a residual pressure type valve or an electric shut of valve available or should I install a manual pet**** inline. Has anyone else had a similar problem and what did you do.Thanks Jack
  2. tb33anda3rd
    tb33anda3rd
    you need a new needle and seat.
    1927graham likes this.
  3. Sheep Dip
    Sheep Dip
    from Central Ca
    desotot likes this.
  4. desotot
    desotot
    thanks SD, I think that's what I need to do. I can't trust a whole bunch of gallons of gas and gravity to a needle and seat.
  5. inthweedz
    inthweedz
    The fuel shut off valve in a dual fuel (LPG) vehicle is what you want, looks the same as the unit above, but has a manual byp*** tap if needed..
    desotot likes this.
  6. desotot
    desotot
    Would any one have a brand name and part # for the part inthweedz refers to ?
  7. gimpyshotrods
    gimpyshotrods
  8. greybeard360
    greybeard360
    Blown power valve won't cause that. It can cause it to be rich while it is running. You have a float and or a needle and seat problem.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    54vicky likes this.
  9. AZbent
    AZbent
    The general aviation world has lots of shutoff valves for fuel. When I was working at restoring Luscombe airplanes, we sold a lot of the valves. A quarter turn and the valve was either open or closed.
  10. inthweedz
    inthweedz
    Hey desotot, do a search on evilbay, '' 12v lpg fuel shutoff solenoid'' they are listed there..
  11. desotot
    desotot
    Thanks guys, I called a local propane conversion shop and they have the valves in stock so I will grab one today. I changed out the carb for a new one but I won't trust a needle and seat to a gravity feed fuel system. Unless I build a custom intake and use 8 updraft carbs.
  12. Ebbsspeed
    Ebbsspeed
    A small bonus for a manually operated shutoff is that it may foil a theft attempt.
  13. flatheadpete
    flatheadpete
    from Burton, MI
    My Ford 9N tractor has a manual fuel valve on it. 2 Turns and it runs off the primary fuel. 5 turns and it runs off the reserve fuel.
  14. jimmy six
    jimmy six
    Nitrous oxide systems guys sell them. A great theft device too.
