Electric Power Steering Collumn
Discussion in 'Off Topic Hot Rods & Customs' started by coop46, Dec 24, 2025.
  1. coop46
    coop46
    from New Jersey
    Hey guys....I'm using a bare stripped down Saturn View EPS column and can't wrap my head around how to do a br*** contact ring & brush pin setup so I can use the horn ****on on the aftermarket steering wheel. I could put a ****on on the dash or console but would prefer to use the steering wheel horn ****on. Has anyone done this?
    down-the-road likes this.
  2. RodStRace
    RodStRace
    I'd guess they are like all modern steering setups where they use a ribbon connector (clockspring) for all wheel mounted functions. Pictures would help, but really, it's a matter of using that part and having a typical horn ****on, or replacing it with complete old style slip ring.
    Here's one example, ignore the brand.
    https://www.bmw2002faq.com/forums/topic/256918-pics-of-horn-slip-ring-attachment/
    All it's got to do is have a relay trigger wire feed to the ****on. Pressing on the ****on grounds the circuit to the steering column/shaft, closing the relay. It will need to be insulated so expect some plastic or other non-conductive parts.
  3. early Willys Jeep stuff
  4. pprather
    pprather
  5. RodStRace
    RodStRace
    Since air bags became common, steering wheel replacement became rare.
    No simple column adapters, difficulty in keeping a shaped air bag in the design.
    The power ***ist at the end doesn't enter into it.
    I get the humor, though.
