Technical Electric speedometer
Discussion in 'The Hokey Ass Message Board' started by thompsonwayne1, Feb 2, 2016.
  1. thompsonwayne1
    thompsonwayne1
    Took the old 39 ford ****** with a mechanical speedometer out of my hot rod and replaced it with a 91 camero 5 speed. It has a electrical terminal for a speedometer, I see stewart warner sell an electric speedometer. Do I just hook it up and go or do I need some other parts like a sending unit or something?
    Thanks
  2. FrozenMerc
    FrozenMerc
    You will need to determine what input signal the speedo takes and what type of signal the sender in the ****** puts out. Most electric speedo's use just a digital pulse count input signal, but I have seen some with DC pulse width modulated (PWM) signals as well. The OEM's like to use PWM senders for their cruise control systems. Stewart Warner should be able to provide a sender that will work with their speedo.
