Technical Electrical Gremlin - No Power
Discussion in 'The Hokey Ass Message Board' started by MrHavard, Sep 11, 2022.
  1. That, sir , indicates to me the connection between the cable and fitting is suspect. I bet it would take very little to pull the cable free.
    Ben
  2. Ebbsspeed
    Ebbsspeed
    ....and the increased resistance creates more heat. Kind of a runaway train situation.
    X-cpe likes this.
  3. poncho catalina
    poncho catalina
    from summit il
    I would look at firewall connector and fuse panel. I have a 64 Pontiac and had same issue. Later GM cars the connector to the fuse panel had a bolt to keep it in place.
  4. MrHavard
    MrHavard
    yep, I am thinking this is the big culprit now. I got stranded on the side of the road the other day after it lost power. When I popped the hood, that suspect ground wire was like a wet noodle. It’s like the conduit had melted inside the sleeve. Replaced it and bolted it to the head instead of the manifold.
    6-bangertim likes this.
