Electrical help, resistor smoking...
Discussion in 'The Hokey Ass Message Board' started by babblewon, Dec 21, 2010.
  1. babblewon
    babblewon
    from cali
    Ok so I went to test fire and check the electrical today.
    When I turned the ignition to acc the balast resistor started smoking. It's brand new.
    I tested 12v coming from the ign s/w into the resistor and only like 4v coming out and then comes the smoke.
    Can someone give me a diagram of proper ign wiring?
    I used one from here to wire it.
    I also have problems with the starter relay not getting 12v out to the starter. Have 12v in and on the ign start wire I turn the key and get 12v at that post but still nothing out of the relay to the starter. At the starter the big post and start post are jumpered together. Need a new relay maybe? Seperate problem.
    Here's what I got
    chevy 350
    distributor has points
    using starter aux relay
    right now I have
    ign coil wire to resistor,
    out of resistor to + coil
    dist. Wire to - coil
    aux relay
    positive batt in (big post)
    heavy wire to starter out(big post)
    small start wire from ign s/w to aux small post
    other small post on aux relay goes to other small post on starter and also to +
    coil
    do I need the ign circuit tied into the starter and starter circuit?
    Can I use the aux relay for just the starter and ditch the ign wires from it and on the starter?
    Input or diagrams would be great, thanks
  2. thunderbirdesq
    thunderbirdesq
    Sometimes they do that when they're brand new. Happens every time I install a new one on something. If it doesn't stop within a few minutes, you may have a problem.
  3. Not unusual. This too will p***.
    Don
  4. squirrel
    try starting the engine? instead of leaving it sitting with the points closed and power to it
    Should be only getting power to the ballast resistor when they key is in the "run" position, not acc. The reason they have an acc position is to run the accessories without the ignition getting power.
  5. JAWS
    JAWS
    Yup, ballast resistors always smoke when "fired" for the first time.
  6. propwash
    propwash
    from Las Vegas
  7. brigrat
    brigrat
    from Wa.St.
    4V? I thought it was supposed to be 9V coming out..................
  8. BISHOP
    BISHOP
    Like bigrat said, you should more like 8-9 coming out. I would check the voltage while its running too.
  9. F&J
    F&J
    If all else fails....wire it like GM did..:confused:
    WTH is a aux relay, and do you need it?
    Like was said ACCY should not power the ballast.
    You say 4V at the coil...somethings wrong. Too much load will overheat the ballast.
    Wire it like gm. Problem solved.
  10. babblewon
    babblewon
    from cali
    Oh ya I mean run position, oops.
    Ok good to know, never installed a new resistor.
    How about the ign circuit being tied into the starter?
    Do I need to do that or just run them seperate.
    I'm a bike guy so not sure.
    On a bike it's totally seperate.
    Does anyone have a good gm diagram or basic gm diagram.
    Maybe a link to one.
    Thanks again, super quick responses!
  11. F&J
    F&J
    skip the relay. I don't see why you want one.
    run one wire from coil + side to starter solenoid small outside terminal marked I for ignition.
    run the wire from key switch terminal marked I, to the input of the ballast.
    run output of the ballast to coil + side.
    run the starter crank wire on Ign switch that is marked S, to the inboard small terminal marked S on the solenoid.
    run the dist points/cond wire to - term on coil.
    How it works: With just the key ON, power to feed the coil will only get there by going through the ballast.(so it will be less than 12v, IF the points are closed) It will read 12 if the points are open (no load)
    When you "crank it", the solenoid movement puts full voltage OUT of the I terminal on the solenoid, which will byp*** the ballast and goes directly to power the coil...but only when cranking.
    4 volts at coil is not right...something is putting too much load on the ballast. Ballasts are simple wire resistors and these types of resistors will show much lower output volts if the load increases beyond specs.
    A resistor will also read higher, if there is very little load on it.
  12. flthd
    flthd
    Mine smoked too but 4 volts sounds low.
  13. babblewon
    babblewon
    from cali
    Awesome thanks, guess I got some work to do tomorrow!
  14. 325w
    325w
    Don't touch it....Ask me how I know..............
  15. babblewon
    babblewon
    from cali
  16. thunderbirdesq
    thunderbirdesq
    He means it's HOT!!
  17. babblewon
    babblewon
    from cali
    Gotcha, too late!!!!
