Hot Rods electrical plug on 8.8
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Sep 4, 2015.
  1. Bonehead II
    Bonehead II
    I just picked up an 8.8 rear out of an 1998 Explorer, it has an electrical plug on the housing with two wires coming into it ? Does this engage the limited slip ??
    Thanks
    Mike
  2. tb33anda3rd
    tb33anda3rd
    antilock brake sensor......i think.
    Hnstray likes this.
  3. mcmopar
    mcmopar
    from Strum, wi
    No, that plug has nothing to do with the limited slip.
  4. Bonehead II
    Bonehead II
    So I guess, I don't need it ?
  5. flamin01a
    flamin01a
  6. Chucky
    Chucky
    Cut the wires - you don't need it.
  7. deathrowdave
    deathrowdave
    from NKy
    Speed/anti loc nothing to do with operation of the axle
  8. treb11
    treb11
    BUT ! you could use it to provide the pulse signal for an electronic speedometer if needed. Just sayin'
    Hnstray likes this.
  9. Hnstray
    Hnstray
    from Quincy, IL
    If this is true, what a great idea...........Thanks. :)
    Otherwise, you can remove the receptacle (if you wish) and make a little plate to cover the port.
    Ray
  10. Bonehead II
    Bonehead II
    Thanks...Guys
    Mike
  11. saltflats
    saltflats
    from Missouri
    You can leave it there to catch any metal that happens to be floating around.
  12. mgtstumpy
    mgtstumpy
    It's the ABS speed sensor, not needed in your application. There's a wheel attached to the crown wheel that triggers the sensor. You can leave it there or remove and cover with a plate. I've seen this done and the protective ears either side of the sensor just ground off. There's an O-ring under the sensor shoulder that prevents oil leakage due to pressure inside when in motion.
    [​IMG][​IMG]
  13. Yep, just like the mad max's blower
