Technical Electrical problem that is soundly beating me
Discussion in 'The Hokey Ass Message Board' started by ArtGeco, Feb 16, 2016.
  1. The electronic ones are fine if you get a good one; it's the ****py quality control on the cheap offshore units that's the problem. Ford even went to the electronic ones as OEM in the late 70s which is where the design came from. Anytime I can pick up a OEM Ford electronic one used, I do because they rarely fail.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Exactly. I also do the same. I will always pick up a NOS ford regulator. Regardless of whether I need one or not.
  3. Engine man
    Engine man
    from Wisconsin
    The one I posted is chrome but they are available painted from Jegs. One caution though, these are 100 amp units compared to the probably 35 amp original. You shouldn't use the original wiring. It is too small to handle the current and could cause a fire. Connect it directly to the battery or starter solenoid with at least number 6 wire. Your amp meter might not work as the alternator wires were usually run through them. Install an idiot light or volt meter instead.
  4. brigrat
    brigrat
    from Wa.St.
    Well, any updates???????????????????????????
