electrical question
Discussion in 'The Hokey Ass Message Board' started by thewildturkey46, Aug 13, 2008.
  1. thewildturkey46
    thewildturkey46
    from Rice, MN
    when replacing my battery, I hooked the positive cable first, when hooking up the ground cable there was a small spark, I shut off the master kill switch and hooked it on with no spark. I do have a radio and tape player that has memory so they are hot with ignition switch off, would that be the cause of the spark at the ground cable? I dont recall of this happening before. thanks
  2. squirrel
    Probably the radio or some other thing that has a capacitor in it. I would not worry about it.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep, radio with a memory circut has a small draw. Will run down a battery over time without that disconnect switch.
  4. Mad~Max
    Mad~Max
    Wheyou first hook the battery up there's a load on the battery, so it will spark. Perfectly normal.
  5. thewildturkey46
    thewildturkey46
    from Rice, MN
    Thanks guys, I knew it would drain the battery, but the spark kind a thru me..thanks
  6. pull the fuse for the radio and tape player and see if it still does it
  7. 325w
    325w
    Try draining the electrical system before doing any service work on it..............
