Technical Electrolosis on loaded block
Discussion in 'The Hokey Ass Message Board' started by Flathead Freddie, Jun 25, 2021.
  1. Flathead Freddie
    Flathead Freddie
    Hi
    Has anyone Electrolosis dipped a block with fully seized crank ***y ?
    Oil pump also froze .
    3 things to gain here :
    Save rods with caps
    Save crank
    Absolutely no cracks wanted
    Yes the water jackets are great
    Freddie's never been bored
    kidcampbell71 likes this.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
    Hmm...because of the way electrolysis works (more a line of sight thing), it may not work well for what you need to do. A better method may be be a soak in something like citric acid, oxalic acid or mol***es.
    Flathead Freddie likes this.
  3. 1ton
    1ton
  4. bobss396
    bobss396
    Mol***es or citric acid works if you can find a big enough tub. I have used citric acid to remove general rust. It doesn't work that well on greasy/dirty things. The mix I use is 1 lb to 5 gallons of water.
  5. rpu28
    rpu28
    from Austin
    Electrolysis will act on any iron that the electrolyte (water in your tub) can reach. But the reaction will be relatively slow in crevices, and even moreso if a crevice is blocked by non-metallic material (like grease).
    So if your seized crank ***embly problem is pistons stuck in their bores, you'd probably be better off using some of the traditional methods for loosening them up.
  6. captainjunk#2
    captainjunk#2
    a barrel of evapo rust maybe
  7. tubman
    tubman
    I do not believe this is a correct statement.
    Saxman and Hnstray like this.
  8. 73RR
    73RR
    Hot tank then citric acid.
  9. Torana68
    Torana68
    from Australia
    those Mole ***es are hard to come by nowadays , a citric acid bath might work but Ive seen it eat cast iron if left too long.
  10. tubman
    tubman
    This is probably the best approach (if you can afford it).
  11. Rust 911 works great
  12. gimpyshotrods
    gimpyshotrods
    Yeah, it is largely line-of-sight. I have tried it on whole doors, with very limited success. That was with using pool noodles to selectively isolate the anode, for the insides. I gave up on that idea.
    "The process of electrolysis is 'line of sight' which means that the current in the electrolyte tends to travel between anodes and cathodes in direct lines rather than around objects that block the "view". For example, only the side of the iron object that faces the anode - waste electrode, will be de-rusted."
    https://www.metaldetectingworld.com...rocess of electrolysis is,, will be de-rusted.
  13. NoRust
    NoRust
    Or for use on old Chrysler hemi engines use RUST-BAN 392. o_O
    Flathead Freddie and Just Gary like this.
  14. Budget36
    Budget36
    Wonder what tastes worse?
  15. lowrd
    lowrd
    Which is rarer, mole ***es or nauga hydes?
    Flathead Freddie and loudbang like this.
  16. beachcruzer
    beachcruzer
    Naugas are now extinct, but there are still plenty of ***es
  17. blue 49
    blue 49
    from Iowa
    I used electrolysis on stuck window regulators before with success, but maybe the washing soda soak did as much good as the electrolysis.
    Gary
  18. rlsteel
    rlsteel
    Antique small engine guys do it that way
  19. junkman8888
    junkman8888
    When I was in high-school dad ran a parts store, in the back was a valve-grinder, flywheel-surfacer and hot-tank which was used to clean my brother's dis***embled FE engine out of his Galaxy convertible. We loaded the parts up one evening and let the hot-tank run all night to get those parts really clean but when we pulled everything out that next day all the parts were coated with what looked like aluminium, in fact everything that got hot-tanked for the next six months came out coated with what looked like aluminum. Apparently you're not supposed to hot-tank stuff like aluminum pistons and intake manifold filler necks.
  20. 73RR
    73RR
    Caustic soda likes to eat aluminum. :rolleyes:
  21. G-son
    G-son
    from Sweden
    I've seen the antique gun (flint lock/percussion cap) guys seem to like boiling their toys in plain water for a few hours, seems to loosen up siezed screws and such pretty well. I've been meaning to try it out, haven't got that far yet.
  22. Water is the best rust solvent. But, once you get it loose, got to dry the water out as soon as you can.
    Flathead Freddie, stanlow69 and G-son like this.
  23. 57 Fargo
    57 Fargo
    Do not put anything aluminum in a caustic tank, it’ll disappear as well as kill the ph in the tank, that’s how we neutralize the fluid in ours for disposal, we put a bunch of old pistons in it
  24. G-son
    G-son
    from Sweden
    Well... That's one way to solve the problem removal of siezed pistons can be! ;)
    Flathead Freddie and Budget36 like this.
  25. Budget36
    Budget36
    Will eat away cam bearing too I’ve been told.
  26. 57 Fargo
    57 Fargo
    Won’t eat the cam bearings they will still be there, just not very happy!
    We once put a fan off a corvette in ours not realizing the blades were aluminum (painted black) when we pulled it out a couple days later we had a fan hub.
  27. Mr48chev
    You can't use a regular hot tank with caustic soda on that one for exactly that reason. Had a kid decide he was going to hot tank an aluminum timing cover once and it was a sad looking piece after it sat in the hot tank overnight.
    55 gallon drums with removable tops aren't real hard to find and if you could find a plastic one it would make an excellent de rust tank to set a block in with a chain hoist or cherry picker. You could also seal it up so your solution didn't evaporate.
    Mol***es works pretty good but stinks to beat hell and you don't want it in the shop or close to the house.
    Evapo-Rust is spendy but if you could seal the container you could use it for a long time on lots off stuff before you wore it out. Plus we always have something we could stick in it if we had it in the bottom of a 55 gallon barrel.
  28. Flathead Freddie
    Flathead Freddie
    Wow thank you and makes sense
  29. Flathead Freddie
    Flathead Freddie
    Thank you important to know
  30. Flathead Freddie
    Flathead Freddie
    Water has oxygen so simple but yes need to take over the oven send mom to bingo and the wife to the sewing machine
