Technical Electronic Ignition/coil question.
Discussion in 'The Hokey Ass Message Board' started by Al T, Aug 30, 2020.
  1. I’ve got an OT car that I’m doing a restoration on. I picked up a stock tach drive distributor for it with an electronic ignition installed. Does anyone recognize this ignition module?
    I’m just wondering if I can use a conventional internal ballast coil with
    CDE78D77-15E9-4F8B-956F-B89FD49EFECE.jpeg D3307559-3579-426C-9FD1-726D1A39528D.jpeg
    Thanks in advance.
    Allan
  2. 54vicky
    54vicky
    not sure other than I believe hall effect just wondering what the hell those bolts and nuts are for?does the orange colour offer a clue as to engine make?just curious
  3. If you’re talking about the rotor, I’m ***uming that’s how the rotor connects to the “plate” that signals the ignition module?
    Its a ‘71 LS5 plastic car.
  4. Mr48chev
    I'm thinking the machine screws and nuts are there for clearance for the module. I'm thinking that that black disk below the weights may be a shield of some sort.
    Lot #31 AJ-NV5M leads to pages showing Pertrionix items with similar numbers that may be their old numbering system.
    There was a Delco transistor ignition for that year of Corvette though. The K66 option but the pickup coil would probably take up that space
    173869258840 Ebay item showing the pickup coil.
  5. Thanks. Never thought to Google the sticker. D’oh! Now just need to find out if an original type internal resistor coil will work.
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    First generation Pertronix, very reliable for the most part!
    KK
