Technical Electronic Ignition conversion in 53' Caddy
Discussion in 'The Hokey Ass Message Board' started by Grease53Monkey, Mar 29, 2016.
  1. Grease53Monkey
    Grease53Monkey
    Hi all. I am looking to put an electronic ignition in my 53 Cadillac with the stock 331. Having some questions about which one I need to go with.. Anything GM that covers those years should work, correct? It's the 12V system. Thanks in advance!
  2. Grease53Monkey
    Grease53Monkey
    Also think I'm going to go with the Accel setup
  3. mgtstumpy
    mgtstumpy
  4. wbrw32
    wbrw32
    Nothing is wrong with the stock one...why screw it up? don't need any damn electronics
    cad-lasalle and 302GMC like this.
  5. khead47
    khead47
    ^^^^^^^^^^^^^What he said!
  6. BJR
    BJR
    Pertronix, and get the coil from them also.
  7. GMC BUBBA
    GMC BUBBA
    Points all the way with that one..............
    Be very carefull what coil you use with the pertronixs ....Make sure its no low ohms ( less than 1.5)...
  8. Grease53Monkey
    Grease53Monkey
    I went with the Pertronix set up and it runs great. I just wanted to eliminate the need for replacing points and it's running the balls so I'm happy with it overall. Thanks for the input guys
    hotroddon likes this.
  9. 302GMC
    302GMC
    from Idaho
    There is no need to replace points if you know how to install them. You need only the right condenser & points, & a dab of cam lube every few thousand miles.
    Happy your new Chinese made parts work.
    I'd find a spare '53 Cad distributor, correctly install Delco points made around 1959 (bakelite rubbing block), bag it up & keep it in the trunk if you leave town ...
    wbrw32 likes this.
  10. Grease53Monkey
    Grease53Monkey
    To each his own pal. I'll give it a shot. If it doesn't work out then I'll go back but any way you cut it it's less maintenance and as long as you know how to wire things and have good connections it should be fine. With that said if it ****s out I know it's a bad product. Points where replaced with electronic for a reason. [emoji6]
  11. hrm2k
    hrm2k
    I'm running the perTronix unit in my coupe ( sbc ) , my 65 V8 Corvair and a 64 Caddy. They work fine. Points are great but the PerTronix unit eliminates some routine maintenance
  12. Grease53Monkey
    Grease53Monkey
    Points are great and they worked great for me but just wanted to give this a shot. Glad it's working well for your ride(s)!
  13. Grease53Monkey
    Grease53Monkey
    Question, did you eliminate the ballast resistor when you switched to the electronic ignition? I'm running the ignitor II system
  14. oldolds
    oldolds
    Look here for an easy conversion using a Ford TFI module.
    http://advrider.com/index.php?threads/points-to-electronic-ignition-cheap-easy.417099/
    You can get the parts in the you pull yard. Just disconnect your condenser and install, If unit goes bad just disconnect it and hook up the condenser and drive home. Kind of like having dual ignition.
    When hooked up the points only have 12 volts going thru them. They don't burn up as they are using such low voltage
  15. Grease53Monkey
    Grease53Monkey
    That's an interesting set up! Have you tried it?
  16. hotroddon
    hotroddon
    Really, "no need to replace points if you know how to install them" - Well, except for the fact that they wear out, both the rubbing blocks and the contact surfaces.
    As for your comment "Your new Chinese parts" - You obviously haven't a clue about PerTronix parts. They are made in San Dimas CA, which last time I looked is not part of China, but the Good Ol USA, and they have been for the over 3.5 Million of them that have been made so far.
    Oh, and where exactly does one go shopping for Delco points that were made in 1959? Just curious
  17. hotroddon
    hotroddon
    If you bought our Ignitor II and the correct coil, you should eliminate the ballast resistor, you will get more spark energy. It will run with the ballast in place, but start and run better without it - the system is designed for a full 12V
  18. Grease53Monkey
    Grease53Monkey
    I did remove the resistor and it is running nicely. Fires up quick and sounds a little healthier too. Thanks Don
  19. Grease53Monkey
    Grease53Monkey
    Some people are just closed minded and think their way is the only way... The WHOLE WORLD went to electronic over points. Just cause that's how they where in the "good ole days" doesn't mean that somethjng better isn't available 65 years later. Yeah I'll take my chances haha
  20. hotroddon
    hotroddon
    "Most" brands of cars stopped using points in 1974 or so. (And now some wag is going to say but my **** Box had them in 1981 or some ****) Seems like 40 years have p***ed and none of the manufacturers have gone back to them. Hmmmmm
  21. Grease53Monkey
    Grease53Monkey
