Technical Electronic ignition
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 29, 2014.
  1. stimpy
    stimpy
    no problem chopped .
  2. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Danny I have no experience with HEIs. But I do have experience with Pertronixs. Very reliable and easy to use. I have one in my Roadster and one in my Falcon. Both are inside Mallory dual point dizzys. What you are describing is Thermal breakdown. A new module should cure it.
    Good Luck
  3. HOTRODPRIMER
    HOTRODPRIMER
    David,like you I don't know anything about these things ether.
    This is what I have for better or worse. HRP
    Is this what you guys are talking about?.
  4. saltflats
    saltflats
    from Missouri
    You can take the module to the parts store and have it tested.
  5. HOTRODPRIMER
    HOTRODPRIMER
    That's what I need to hear!,,thanks man. HRP
  6. saltflats
    saltflats
    from Missouri
    Have them test it several time it will heat it up if it fails when it gets hot.
  7. i.rant
    i.rant
    If you need to replace it pays to get the real thing from GM, cheap ones are garbage.
    Posted using the Full Custom H.A.M.B. App
    tb33anda3rd likes this.
  8. squirrel
    Did you wipe the white grease off the bottom of it? should be a heavy coating there. That's really all you need to worry about as far as installation...oh, make sure the wires are plugged on firmly.
    I don't have any recommendations for brands, I can't even recommend GM stuff any more, they don't make it like they used to. All I can suggest is that you keep a spare module with you, if only to satisfy Mr. Murphy (if you have a spare, you won't need it)
  9. HOTRODPRIMER
    HOTRODPRIMER
    Yeah Jim,I wiped of the heavy coating of white grease off
    Murphy has been tailing me lately so I know what you mean! HRP
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Hopefully a new module gets you back on the road.
  11. 55 dude
    55 dude
    those modules can fail ANYTIME! man if yours is sputtering consider yourself lucky because it's saying "CHANGE ME" or your gonna change me along the road and it will be 100 degrees or raining!i alway carry a spare and tools to swap it out.
  12. 57countrysedan
    57countrysedan
    from NY
    Id start at the basics before throwing parts. If its missing on idle pull wires and check for a change. If no change thats the cylinder. Then u can swap a plug cylinder to cylinder and see if it follow or even try moving wires around. Thats just how id do it. Good luck!
  13. mikhett
    mikhett
    from jackson nj
    You can troubleshoot with canned air.turn it upside down and it sprays a ice cold spray.good for checking thermal problems in electronic ignitions.Also Heat sink compound ios what u need on the underside of the module.you can get it at radio shack!
  14. stimpy
    stimpy
    only good ones I have run into anymore are accel or Blue standard , and the accel ones are only better for the High rpm ( over 4500) as it doesn't retard like the OEm ones do
  15. Last edited: Jun 30, 2014
  16. brokenspoke
    brokenspoke
    I'm thinking pick up coil is going bad.....
  17. HOTRODPRIMER
    HOTRODPRIMER
    Back to square one....
    The module check out OK but I put a new one in anyway,I also put in a new rotor ****on,the wires are not crossed and all the plugs are good.
    The distributor is tight..I fired the car up and it's still spitting and sputtering and cuts off. HRP
  18. stimpy
    stimpy
    check the cap for carbon tracking ( hard to do with a black cap that s why I like the blue or tan ones ) as if there is any of the red dust ( ozoned metal) it will make carbon tracks easily in the unit also try not to use a aluminum post cap as the aluminum over times develops a oxide on the terminals and can cause cross firing issues or missing from the burned off bits . the br*** term caps will last 4x as long too .
    Heavy Flat Head likes this.
  19. squirrel
    Might check the voltage at the distributor B terminal, make sure it's getting full battery voltage when it's running bad. Someone mentioned the pickup coil possibly getting flaky, too.
    And we all know that 95% of carb problems are caused by the ignition...but it works the other way, too
  20. HOTRODPRIMER
    HOTRODPRIMER
    Sorry about that ,I omitted that I also have a new cap. HRP
  21. HOTRODPRIMER
    HOTRODPRIMER
    Well,the coil pack is the only thing that I haven't changed. HRP
  22. stimpy
    stimpy
    a old 70's chilton manual has the ohm specs in it and the wire colors do mean something ( yellow or white) it has to do with magnatism and the way its wound , but chevy is 95% red and white wires .
  23. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Fuel system and carb ok? Valve rocker clearances ok? Is it possible that you lunched a cam lobe? Any audible evidence of a collapsed lifter?
  24. Commish
    Commish
    from NW Ok
    It may have been mentioned, but go over the wires and plugs that plug on to the pickup coil and module. Had one coming of one end of a module that was broke inside the insulation, intermittent miss. Like to never found it.
  25. ago
    ago
    from pgh. pa.
    Heat paste can be bought at Radio Shack.
    Ago
  26. GMC BUBBA
    GMC BUBBA
    GM ( Delco) no longer makes a good one either !! All are off shore units ...
  27. ROADSTER1927
    ROADSTER1927
    HRP, have you put a timing light on it to see if it is missing sparks? that is quick and easy! I would also bet on the pickup coil being the problem. Gary
  28. bonzo-1
    bonzo-1
    I have had a weak coil that would let the motor idle but would then break up under load and rpm.
  29. harpo1313
    harpo1313
    from wareham,ma
    could also check your engine ground.
  30. tommy
    tommy
    Not trying to insult you but this seems like a perfect time to get rid of that ugly thing.:D I bet GMC Bubba can build you a nice electronic window points dist. Modern ign. and a pretty case. Your dist. is ugly! there I said it sorry.:p
