Technical Electronic ignition
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 29, 2014.
  1. brokenspoke
    brokenspoke
    At least it didn't catch on fire.....
  2. Stevie Nash
    Stevie Nash
    I had a faulty coil in an HEI that caused similar problems....
  3. Merlin
    Merlin
    from Inman, SC
    Yep very lucky. I would change all the fuel hose with the fuel injection rated stuff pretty soon.
  4. stimpy
    stimpy
    word of warning on the modules make sure you have a resistance source ( like plugs on the wires ) if you test it out of the car as if there isn't a circuit it can kill the amplifier module ,
    glad you found your culprit , them coils do loose there umph as they get older, if they are not OEM they go real quick except of the " racing ones " often the resin cooks between the wires and they short . at least yours was a easy problem to solve, I had one that sat for a week with us scratching our heads , we replaced the cap , coil , and rotor ,with customer supplied parts , only to have it start run a few minutes then stop dead . and wouldn't refire , all the electronics was good ( module , coil , pickup) , it was the cheap rotor burned thru under it and was shorting out on the distributor shaft , and the replacement rotor was also bad ( cheap no name parts ) wasn't till I put a used worn 75,000 mile Gm rotor in it as hunch it fired up . we looked at the bottom of the new rotor and you could barely see the burn thru . it was a pinhole . ever since then its been nothing but AC Delco , Acell ,MSd or Standard Ign. for parts for them .
  5. HOTRODPRIMER
    HOTRODPRIMER
    When I got the car back from Rogers wife a couple of years ago I replaced all the rubber fuel lines under the hood,but that small piece between the gas tank and the hard line was out of sight out of mind. :rolleyes: HRP
  6. HRP
    I am known as a "Cheby guy" and I don't run the HEI. Does that tell you anything? :D
    I know that it has ben a PITA but I got to laugh, there is an old saying, that all electrical problems are fuel related and all fuel problems are electrical. you proved it. ;)
    Happy for a couple of reason here, one is that you are back on the road and the other is that you are still on the road. car fires are nasty and a bad fuel line can cause them faster then a rat running over the roof with a piece of raw liver in its mouth. :D
  7. tedley
    tedley
    from canada
    I find the cheapo petronics 1 is the longest lasting. 14 years and counting on one, never skips a beat. Had trouble with flame thrower 2 and switched the cheapo. It's all good.
    Bubba1955 likes this.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Happy to report I drove the car about 20 miles today and ran like a champ and no hard cold starting problem this morning.
    Our weekly hot dogs & hot rods only had 2 hot rods show up,several others showed up in family cars. :rolleyes: HRP hd&hr.jpg
