Hot Rods emergency brake
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 19, 2022.
  1. sdluck
    sdluck
    some year 914 also.
    VANDENPLAS likes this.
  2. sdluck
    sdluck
    Lots of good ideas,But not much room in a model a roadster with stick shift and a bench seat. I used the on that was in the car before and made a bracket to mount it next to the shifter,but it doesn't pull right.
  3. jetnow1
    jetnow1
    from CT
    On my 50 chevy truck I used the stock release mechanism; at the rear I have an explorer rear axle that I used 2 of the
    left side cables adapted to the stock crossbar. The right-side cable is twice as long as I needed.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    You've got a bunch more room than I have in my tbucket , yet I have three pedals , a dimmer switch & the shifter & ebrake handle , all floor mounted plus p***enger leg & foot room !
  5. sdluck
    sdluck
    Can you send me a picture
    2OLD2FAST likes this.
  6. Johnboy34
    Johnboy34
    from Seattle,Wa
  7. gimpyshotrods
    gimpyshotrods
    It also looks Beetle-esque, so it might originate there.
  8. evintho
    evintho
    Junkyard. The E-brake boot may be a boot from an '80s Honda and I made the plate that secures it to the floor. The shifter boot is the factory boot from a TurboCoupe. Made the plate for that too. Just go to PickNPull down there on Commercial st., bring a tape measure, poke around and see what you can find!
  9. blue 49
    blue 49
    from Iowa
    mad mikey likes this.
  10. I'm mocking mine up in the early '28 spot, not sure what the handle is from but it's old. I'll see if it works, but I think it should.
  11. Hotrodmyk
    Hotrodmyk
    It is a small hand brake ***embly as used on forklifts and that type of industrial equipment.
    Tman, ElmCityGeoff and '28phonebooth like this.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Car is in storage for the winter , sorry not unwrapping for picture . I'll look & see if there's an old one .
  13. sdluck
    sdluck
  14. rdscotty
    rdscotty
    from red deer
    1950 GM car underdash unit. Straight pull, no pivoting arm. Keeps it off the floor and away from the kick panel if foot room is an issue.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    IMG_20220223_092807.jpg @sdluck , this is a pic of a pic , don't know if this helps or not ?
  16. sdluck
    sdluck
    thank you,I need info on the cable hook up to the handle.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    This is what I shamelessly copied with changes made for stock cable ends & some minor changes to bracketry Screenshot_2022-02-23-14-06-05.png
  18. Bandit Billy
    Bandit Billy
    I built a bracket to hold a LoCar e-brake to my T-5 next to the stick.
    And then I made a hump in the floor to surround the stick and e-brake handles so they sat flush and made a single aluminum plate to finish it. I recessed the boots into the plate so you can't see the leather edges and countered the screws into as well.
  19. Dino 64
    Dino 64
    from Virginia
    Just Gary likes this.
  20. Used one from a rusted out '70s Jeep Wagoneer I found in the junkyard on the '38 Ford pickup. Real hot rodders find solutions to all kinds of problems at Pick-a-Part. There is a cheap, simple junkyard solution to most problems like this.
