Hot Rods Emergency/park brake - Do you have one?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jan 9, 2019.
  1. HOTRODPRIMER
    HOTRODPRIMER
    we were talking about this at the hot rod lunch and I had to admit I don't have one on my old deuce, there is one on the Ranch Wagon & the '50 coupe.
    While I've got the Deuce down for the interior, window channel repair, plumbing the heater I might as well think about a real emergency brake instead of the occasional ruck when I'm parked on a hill.
    I sure would like to see what you guys have used. HRP
  2. blowby
    blowby
    from Nicasio Ca
  3. Buddy Palumbo
    Buddy Palumbo
    Yup, I have a working parking brake on my Shoebox. Still a stock rear, so no issue. When I install the maverick rear, I'll have to figure it out, but it WILL work.
    BoilermakerDave and HOTRODPRIMER like this.
  4. DDDenny
  5. Mr48chev
    Required by law in most states. I've got one in the 48 but will admit that the pedal is so high on the kick panel that using it in an "emergency" might be an issue but it works great to hold the truck in place when parked on an incline. I used it a lot more when the 250 got tired and didn't have the compression to hold the truck in place and be trusted to keep it there on an incline.
    Bruce Fischer and HOTRODPRIMER like this.
  6. 56don
    56don
    Danny, for the 32 coupe I utilized the parking brake out of my 34 truck and fabricated a mount for it. Don't have a photo of it though. I couldn't stand that brake setup that was on it when I bought it.
    Then later I wished I had used something else because I needed one for the truck so I used the same style parking brake lever that came with a 36 Chevy truck I once owned.
    HOTRODPRIMER likes this.
  7. Al's.C.D.T
    Al's.C.D.T
    Compulsory over here.
  8. Gman0046
    Gman0046
    Wouldn't drive a car without a parking brake. Rather have one and not use it then need one and not have it. Using a rock for a parking brake is just a little too primitive for me. A Lokar parking brake ***embly for a 32 Ford is an easy installation. Cheap insurance as well.
    Gary
  9. 3 window Mike
    3 window Mike
    This is in my 3 Window . It's modified ,but from a Tri 5 Chevy . Left side of the steering column and out of the way. 20190109_192120.jpg
  10. deathrowdave
    deathrowdave
    from NKy
    I used a Chebbie van , left side of the 32 , tied into lokar cables to a 9 in axle . It will lock the brakes while moving and God could not move it while parked with it on
  11. HOTRODPRIMER
    HOTRODPRIMER
    Thanks for the ideas.HRP
  12. norms30a
    norms30a
    In my early 20s I built a T bucket and when it was drive-able I was really thrilled, so the first chance I had I drove it to town. In town it started to idle rough, so I stopped on the side of the street to fiddle with the carburetor. In the process of climbing out I kicked the shift lever into gear, well of course the light car started rolling forward. Directly in front of me were 3 fully chromed and customized Harley Davidson bikes that guys had parked for a rest on their way to the Sturgis bike rally. In a split second I threw my *** onto the side of the bucket and cranked the steering wheel hard to the left to miss the bikes, then I went on down the street with both feet hanging over the side. I turned a corner and idled into a residential area with lots of room there I could get my feet in where they were supposed to be. I went directly home and did not drive it again until I had a pinto pull lever and E brake cables in and working really good. I had the **** scared out of me in those moments, so now ever since then nothing ever leaves my shop without a E brake in and working really good.
  13. norms30a
    norms30a
    mgtstumpy and HOTRODPRIMER like this.
  14. F&J
    F&J
    Mine has an original chrome 33/34 Ford handle that I found at the V8 Ford meet in M***achusetts for $20. I run a mid 50s Olds rear with cables and the brake works so well with the stock Ford leverage ratio, that the engine will stall if you forget that it is still on.
    Whenever mine is parked, the handbrake is always on, and out of gear. I do that as I've seen where a person reaches in to start the car, and forgets that it is in gear. Not often, but something to consider as we get "elderly" :oops:or are overtired.
    It took a long time to build the car as I wanted every thing to be in the perfect spot for my arm & body size, and by setting the handbrake every time you stop/park, you then train your subconscious to know exactly where it is without even looking,,,,in case there ever was a brake failure even at night. I also took the time to get it placed where it is not in the way if somebody slides over from the p***enger side like the pic below.
    Here the trans is in 2nd gear, as I knew kids would be climbing around in it during a recent Christmas festival. She scooched right over no problem with the handbrake on.
  15. da34guy
    da34guy
    The Brick @ Bako.jpg This works better than a rock Danny. My E-Brick, 1 problem I do have though, really hard to find brick fluid
  16. olscrounger
    olscrounger
    Ebrakes in all I do and working as they should. Old habit of always setting them every time I park. Was coming home from uph shop in a fresh 40 in 5 oclock traffic. Front new brake line broke (new braided one-never again)!! pedal went down-dual master and all but sketchy brakes. Drove it all the way home in traffic slowly using the ebrake-no problem.
    HOTRODPRIMER and i.rant like this.
  17. Bandit Billy
    Bandit Billy
    I posted my truck e brake idea to the "other" thread, on this one I will post the 34's I built. I welded up a bracket during construction that placed the handle alongside the T-5 shifter and built the tunnel and polished shifter plate so as to make it look like it grew there. Holds tight! Looks right!
    HOTRODPRIMER and olscrounger like this.
  18. I always try and have one. I have gone a day or two without one but I always have one as soon as I can.
    For me they are an E Brake. I guess I just never made it out of the 20th Century.
  19. HOTRODPRIMER
    HOTRODPRIMER
  20. HOTRODPRIMER
    HOTRODPRIMER
    I'm leaning toward the low out of the way emergency brake similar to this. HRP
  21. Fordors
    Fordors
    I have a Pinto e-brake handle with Lokar cables in my channeled coupe, for sure the one you show was patterned after the OEM Pinto.
    In my coupe it’s an easy reach and I could still steer and see the road. On the other hand in your Tudor with a higher seating position it might not be so user friendly if you needed it in an emergency situation.
    If you have ever had a front brake line go out in a late model, dual master vehicle, yes you still have brakes but the stopping power is greatly diminished. Parking brake or emergency brake? I want an e-brake with good accessibility.
  22. Bandit Billy
    Bandit Billy
    ^^^that works. In the 40 ford truck I am preparing to build I am installing this under the dash as I am going column shift on this rig and wanting the floor clear.
    It is the parking brake from a Camaro/chevelle/elky/and a billion other GM cars. I will weld in support braces to make this a bolt in. Probably change that pedal pad. 69 bucks.
  23. cheap-n-dirty
    cheap-n-dirty
    here's mine , with a 4 speed you need one.
  24. rustydusty
    rustydusty
    I would like to have one, but the original drive train had it on the transmission. She now has a 727 trans with no accommodations for an emergency brake. The rear has the original drum brakes with no e-brake access either. Is there any kind of kit that might work?
  25. Hotrodmyk
    Hotrodmyk
    This is exactly what I used, stashed it under the seat.
  26. Hotrodmyk
    Hotrodmyk
    I used components from "Control Cables" in Santa Fe Springs, CA.
    LOWDUG37 and HOTRODPRIMER like this.
  27. Bandit Billy
    Bandit Billy
    ^^^^Nice Mike! Looks like an ejector seat handle.
    Hotrodmyk and HOTRODPRIMER like this.
  28. Blue One
    Blue One
    from Alberta
    I used the Lokar transmission mounted brake ***embly and their universal cable kit with it.
    I don't think I've ever had an easier time getting the e-brake / parking brake setup installed and working on any car I've ever worked on.
    Really great product.
    mgtstumpy, Joemama, USMercUte and 5 others like this.
  29. HOTRODPRIMER
    HOTRODPRIMER
    I like that a lot and it's out of the way as far as room for your p***enger. HRP
    Hotrodmyk likes this.
  30. DDDenny
    I've always liked the late 60's Corvette e-brake handle ***emblies, a little more difficult to mount though. I put the same one in my roadster that is in my Nova and also put one in my 66 Suburban, but in my roadster I mounted it between the bucket seats, its a bit tight.
    I'll never need it anyway!:eek:
    mgtstumpy, HOTRODPRIMER and Hotrodmyk like this.
