engine and trans are in ? on engine position [pics]
Discussion in 'The Hokey Ass Message Board' started by 54 chev gasser, Mar 20, 2006.
  1. 54 chev gasser
    54 chev gasser
    should i make it level at ride height or 3deg down in the back makin up trans mt
  2. Boones
    Boones
    from Kent, Wa
    the angle of the ****** input shaft should be the same as the rear yoke I believe.... around 3 degrees I believe
  3. With full weight of body and engine resting on the suspension (ride height) the base of the carburetor should be level. On a small block chev, that means that the tailstock of the engine will be sloped down about 3 to 3 1/2 degrees from horizontal.
  4. 54 chev gasser
    54 chev gasser
    ah thats what i thought wasnt sure though sweet thanks
  5. squirrel
    I disagree.....with the car frame/body sitting level, the carb flange should be level.
    Hopefully this will result in the engine being pointed up about 8 degrees, if you have the "proper" g***er stance!
  6. sinwagon49
    sinwagon49
    from mo
    If your carb flange is level the cylinder head is 3 dregees positive which should make your trans pan level as well. The drive line angle must be atleast 2 degrees off center up,down,left,right it don't matter
  7. Squirrel---You are wrong!!! 99% of hotrod bodys and frames are not level when the car is at ride height. The carburetor doesn't care whether the body /ch***is platform is level or tipped up 10 degrees either way. The carburetor wants to have a level base when the car is in its NORMAL OPERATING POSITION.---which is at full engine and body weight on the suspension.
  8. squirrel
    The carburetor doesn't really care....really....and the engine fits a lot better if you put it in so that it's at the designed in 3 to 4 degree nose up tilt relative to the car's frame/body, which means the carb flange will be level when the body/frame is level.
    I suppose you can do whatever you want, but the way I describe is how most folks do it, and it works just fine.
