Engine Balanceing
Discussion in 'The Hokey Ass Message Board' started by johnod, Dec 16, 2011.
  1. johnod
    johnod
    I'm planning on building a short block sbc.
    At some point I'll have to get the rotating ***embly balanced.
    Do I have to know anything, give them specs, or do i just drop off at the shop and tell them to balance it?
    I know nothing about balancing engines.
    Thanks
  2. Mike Miller
    Mike Miller
    Look on U Tube to see what a balance shop does, that will help you understand the procedure. They will want your flywheel and harmonic balancer along with the rotating ***y and pistons.
  3. Babyearl
    Babyearl
    All internal parts, clean or new, pistons off rods, crank, balancer, flywheel, pressure plate. Rings, rod bearings, money.
  4. Sheep Dip
    Sheep Dip
    from Central Ca
    Money well spent!
  5. johnod
    johnod
    Thanks guys, but the important question remains.
    Do I have to supply them some sort of specs as to how I want it balanced, or just drop it all off?
  6. gimpyshotrods
    gimpyshotrods
    They will know what to do.
  7. Mike Miller
    Mike Miller
    The answer is no and yes. If it meets the criteria listed above they will know what to do and hand you a bill.:D
  8. Dyce
    Dyce
    You need the pistons, pins and rings, rods and rod bearings, crank, balancer and flywheel. They are sweet running engines a balanced up!!
  9. If they don't already have the information you are at the wrong shop.
    Charlie Stephens
  10. gene schultz
    gene schultz
    from nebraska
    if the crank came balanced from **** do you still have to balance the whole ***embly or will it run ok the way it is?
  11. gene schultz
    gene schultz
    from nebraska
    If you cant eat it you probably dont need it.
  12. stimpy
    stimpy
    you can rough balance a motor like the OEms do , but with a new crank to make a motor run better its best to have the whole ***y redone if a major component was replaced as its balanced as a group , if your builder has the old build sheet thye can sometimes just machine the crank to make it match the numbers .
  13. sunbeam
    sunbeam
    If it's **** have it balanced. The last one I got was a 350 crank with 400 mains it needed balanced and turned.
  14. Engine man
    Engine man
    from Wisconsin
    What they will do is make all of the pistons and rods the same weight. Then they will spin the crankshaft to balance it. Then they install the harmonic damper and balance it. If you know what belt pulleys you are using they can check those too. Next they install the flywheel and balance that. Then install the pressure plate and balance it. Finally, they will balance the clutch disc on a separate shaft. They will mark everything so it is installed in the correct position.
    Some engines, like the 400 Chevy, have a crankshaft that can't be balanced by itself. It has to be balanced with the damper and flywheel or flexplate installed. The damper and flexplate are made with extra weight to counter the imbalance in the crankshaft. Some shops will try to cut corners and balance every engine like an externally balanced engine because it saves them a couple of steps to balance the damper and flywheel separately.
  15. Pete1
    Pete1
    from Wa.
    You can take all that to the bank.
    "Been balancing stuff for 60 years"
