Engine compartment paint???
Discussion in 'The Hokey Ass Message Board' started by Lo-fi, Jun 11, 2010.
  1. Lo-fi
    Lo-fi
    This may have been covered on here in the past, but I was wondering if anyone could recommend a good paint for re-painting the engine compartment on my 63 Galaxie? I plan on (carefully) painting it with the engine still in it. It's a daily driver, so it doesn't need to be show quality. Just want to spruce up the engine compartment a bit and clean it up. I want to keep it black, but should I use a hi-heat paint? Any particular brand better than the other?
  2. logride
    logride
    from CB IA
    When i was switching to the last small block i have in my 63 galaxie, i painted it flat black rust-oleum, it was different than straight flat black. I can't remember what it was called, but it was just a spray can, had like diamond plate on the label. Not high temp paint or anything, it was when i did the motor before this one. That was in the spring of last year, i like it it's held up fine, you really don't need anything fancy
  3. phat rat
    phat rat
    I use Krylon semi gloss black
  4. logride
    logride
    from CB IA
    A roll of tin foil works great to mask the engine or what ever you don't want painted. It works great!
  5. Evilfordcoupe™
    Evilfordcoupe™
    I just painted the engine bay of our Lincoln with John Deere Blitz Black. Turned our super nice. It was $32 for two quarts and a pint of thinner.
    -Jason
  6. 88 gtu
    88 gtu
  7. Scotts Enterprises
    Scotts Enterprises
    x2, although I spray it first with Ditzler DP90 epoxy primer...
  8. tommy
    tommy
    The best stuff that I have found for the factory semi gloss look. WalMart has the best prices. I keep a couple cans in stock.
  9. Mike51Merc
    Mike51Merc
    Krylon Rust Tough Semi-Flat (not semi-gloss, that's a different product). I love the stuff. No primer necessary, shoots nice, blends great, dries fast.
  10. milwscruffy
    milwscruffy
    That would be semi flat black and it looks great.
  11. Mike51Merc
    Mike51Merc
    Krylon also has semi-gloss black. Don't ask me to describe the difference.
  12. phat rat
    phat rat
    It seems as though when I first used it about 15+ years ago it was labeled semi gloss, it was #1613 back then. I just when and looked at a can and now it's labeled satin and is #51613. As someone said it blends in great. The entire underside of my cpe was originally done in a low sheen/satin and this is what I use to touch it up periodically. Also have used it quite a bit under the hood and it's held up fine.
  13. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Ditto on the Krylon semi-flat, looks factory and lays out nice.
    Find it at Wally-mart 2 cans should do it!
    Dazzlem
