Technical Engine Dies
Discussion in 'The Hokey Ass Message Board' started by AlaskanMatt, Oct 27, 2018.
  1. AlaskanMatt
    AlaskanMatt
    Hey guys, I need some help. I've got a newly rebuilt 383 in my car. It starts and idles just fine. The issue is this, when I put the car in gear it dies. There are no weird noises or anything. It just dies. Any suggestions?
  2. trollst
    trollst
    You sure give enough info to make a guess.....not. More info please, what was replaced, how fast does it idle, is it injected, more boy, more.
  3. jimgoetz
    jimgoetz
    Neutral safety switch ?
    1927graham likes this.
  4. Elcohaulic
    Elcohaulic
    Is there a piece of linkage shorting out a wire..
    Torque converter locked up?
  5. Vacuum leak?
    Over fueling?
    Under fueling?
    High rpm
    Low rpm
    Misfiring
    Advanced timing
    Retarted
    Mechanical issue
    Tune up
    Old engine coming to life
    New engine braking in
    Air conditioning
    Carburated
    Fuel injection
    Old gas
    Manual trans
    Auto trans
    Converter stall
    Some thing mechanical binding
    Valves adjusted right
    Base timing
    What kind of distributor is in it
    Tuna sandwich?
    Sorry my friend, need a bit more info before we fire up the cannon !!
    My first guess would be tune up or vacuum leak but that’s not only a shot in the dark it’s a shot in the dark with an unloaded gun!
    KoolKat-57 and XXL__ like this.
  6. paul philliup
    paul philliup
    from ohio
    383 is that a stoker sbc or a big block Chrysler. What torque converter are you using and what transmisson. How big is your cam. Does it have a carb,fuel injection, or a blower.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Big cam no converter?????
    Black_Sheep and KoolKat-57 like this.
  8. Painfulbanter
    Painfulbanter
    If you give it a little gas, when putting into gear, does it still die?
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  9. khead47
    khead47
    I agree with too much cam with too low stall convertor.
  10. Mr48chev
    Idle speed too low? I'd go along with the converter stall speed being too low though.
  11. Ebbsspeed
    Ebbsspeed
    Fries or onion rings? It's one of few questions that haven't been asked.
    VANDENPLAS likes this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
  13. Or 383 Mercury ...They won't idle low with the wrong carb gasket either ;-)
  14. 283john
    283john
    Jack back tires off the ground. See if it still dies.
