Engine# F022YS
Discussion in 'The Hokey Ass Message Board' started by 3Deuce40, Jun 10, 2013.
  1. 3Deuce40
    3Deuce40
    from Colorado
    Anybody have a clue what this is or out of? I have been unable to find anything that describes this. Any info is much appreciated. Thanks in advance.
  2. hotroddon
    hotroddon
    probably help if you provide a little more info! Ford, Chevy, Packard? 4, 6, 8 or 12 cylinder? kinda shooting in the dark here don't ya think?
  3. mike in tucson
    mike in tucson
    from Tucson
    IF it is a small block Chevy, the YS code indicates a 65-68 327 manual transmission, 4bbl carb installed in a Series 10, 20, or 30 TRUCK. First three years were 220hp, last year was 240hp.
    IF it is not a small block Chevy, I have no clue either
  4. 3Deuce40
    3Deuce40
    from Colorado
    My mistake. Its a small block chevy, has a 4bbl cast iron intake on it with a breather tube. Its got about 6 inches on grease on it so I'm still looking for numbers. The balancer seems to be skinny so I thought 283 at first. Guy claims its a 327 but I have had zero luck locating any info
  5. 3Deuce40
    3Deuce40
    from Colorado
    This wouldnt be a Muncie M20 would it?
  6. mike in tucson
    mike in tucson
    from Tucson
    Chevrolet Engine codes dont specify
  7. mike in tucson
    mike in tucson
    from Tucson
    Chevy engine codes do not identify the trans model on a manual application. However, most 1 ton (series 30) were an M20 4 sp. it is a 327 engine
    What heads? Get a casting number and date code from under the valve cover
