Hot Rods Engine for 49 Ford Coupe?
Discussion in 'The Hokey Ass Message Board' started by nadodave, Nov 4, 2021.
  1. nadodave
    nadodave
    I hope I am on the correct forum. Got my **** shot off last time I posted - fortunately, there is plenty left :). I have a 49 Ford Coupe project car. It came with some sort of Mopar V8 installed and what I think is a 4 speed trans. The engine does not turn, most likely because the carb was removed and the engine was not covered. My question: I had ***umed I would find a SBC to install (the flathead was already gone!), but I was wondering about whether I should rebuild the Mopar instead. I sort of hate just trashing it, but don't want to chase a unicorn either. A Mopar in an old Ford is definitely not something you see every day, and I am not looking for a fire breather, just good performance and freeway cruising. Thoughts?
  2. Budget36
    Budget36
    Pics of what you’re working with might help, as in what kind of Mopar engine is there?
    I might be thinking an LA engine, another guy a Hemi, etc
    lothiandon1940 likes this.
  3. Zax
    Zax
    If the engine is locked up I wouldn’t waste my time unless it was something really special.
    210superair and lothiandon1940 like this.
  4. nadodave
    nadodave
    Right! It is not a hemi, but I don't know if it is a 318 or 360.
    Probably good advice!
  5. Budget36
    Budget36
    Find out why it’s stuck, see what you have to work with.
    If the car ran at one time and the engine and transmission mounts were done well, easiest thing would be find another LA engine. All the guess work of radiator hoses, mounts, driveshaft etc have already been done.
    Do some searching, I think, but can’t state as fact, a new FI 360 Dodge engine mounts the same and might be less pain to start with. I’m not advocating the FI route, but a pick and pull new engine to use as a short block might be an easier option.
  6. Jessie J.
    Jessie J.
    You sure about that?
    61 Fairlane and sunbeam like this.
  7. tubman
    tubman
    I would think that the presence of the 4 speed (if it actually is) would be a large factor in the decision. In the final ****ysis though, you really can't make the "right" decision without a full evaluation of the situation. Is it a quality installation that has just been neglected, or a "hack" job? Was the installation completed (clutch, shift, and throttle linages present and working)? What about the wiring, is it properly done and complete? We need more information.
  8. 61 Fairlane
    61 Fairlane
    Distributor is in the front on a 440
  9. COCONUTS
    COCONUTS
    Well Dave, it does not cost anything to pull it apart and take a "look and see" what you have.
    ottoman and 210superair like this.
  10. 40FORDPU
    40FORDPU
    If you're okay with Mopar power in your Ford, I see no reason to re-invent the wheel, ***ess the present engine/transmission to know what you're working with (identify/determine condition), and freshen it/them up.
