Engine Gooru's...Need help or advice
Discussion in 'The Hokey Ass Message Board' started by Kage, Feb 28, 2012.
  1. Kage
    Kage
    from Delano, TN
    Thanks for all the advice.
  2. These are the 3 Best Engine ***embly lubes used by Pro Engine Builders to date. I endorse all 3, TR
  3. Look to the left of the 1-off crankshaft. This is the Clevite product. The other 2 are both in the cabinet below. It has been said that the white lube will clog the oil filters, and that is correct. In the late 70's we students were taught at Honda Motorcycle Private Training Center to use Anti-Seize on the camshafts and cam journals of the overhead cam Motorcycle engines. Shortly after we were all sent bulletins on NOT to use the anti-seize on the cams and journals as the Engineers in Japan were finding out that this too was clogging oil filters when used incorrectly. Engine oil only. TR
  4. One Finger John
    One Finger John
    Could you measure how many ft/lbs it takes to spin it over and tell us?
  5. One Finger John
    One Finger John
    I also recommend throughly cleaning the crank and using 30 wt. for checking crank movement and determining how many ft./lbs it takes to turn over. Heads are off, right?
  6. y-oh-y
    y-oh-y
    Just hate it when a thread dies before the solution is posted, what was the problem ?
  7. Kage
    Kage
    from Delano, TN
    main caps in the wrong order.
  8. y-oh-y
    y-oh-y
    Thank you, kinda like not seeing the end of a good movie.
