engine hoist jack revival?
Discussion in 'The Hokey Ass Message Board' started by 81ttopcoupe, Jul 5, 2005.
  1. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    I took my engine hoist apart and laid it in the back of my pickup to go pick up a flathead. I didn't need it when I got where I was going, but when I put it back together at home, it would not lift itself. There is absolutely no resistance when I pump the jack. Fluid level seems to be fine. If I lift the boom by hand several times it will stay up, when I release it, it seems to bounce down. It has set for about a year since I last used it, but I think it was working before I put it in the truck. Any suggestions?
  2. the hydraulic ram on my hoist does the same if i lay it on it's side for any period of time , i always make sure i store it standing straight up.
    it kinda acts like there is air in it , like a brake line that needs bleeding. what i have done is open the the screw on the bottom of the ram and pump the handle a bunch of times...that seams to help
  3. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    I was kind of thinking it has air in it, just can't figure how to get it out. I will try leaving the release open and pumping it a bunch. I tried it with it closed but that didn't seem to work.
  4. cabriolethiboy
    cabriolethiboy
    I had that trouble with mine too. I was going to buy a jack cylinder for mine when I got on the Harbor Freight site to check out the different cylinders. At the bottom of the ad it has a note that says download product manual, I think that is what it says. You will figure it out. Anyway it tells how to bleed the air out of the cylinder. It fixed mine. I also downloaded a manual for a floor jack and fixed one that has been setting around for a couple of years.
  5. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    cabriolethiboy
    Thanks for reminding me about that website. That is the hoist I have, those same instructions for bleeding the air are stickered on the jack. Maybe I'm not holding my tongue right. I will try again tonight.
    Thanks,
    Joey
  6. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    It's ALIVE!
    After pumping it about 500 times, both with the valve open and closed, it started moving. After a few times up and down it seems to be working good again.
    Thanks folks.
