Technical Engine id help!
Discussion in 'The Hokey Ass Message Board' started by oldrelics, May 28, 2018.
  1. oldrelics
    oldrelics
    from Calgary
    9BE9E7F4-F872-47C8-AA3C-B232CF0CD45C.jpeg 385268BA-BC15-4029-A93D-7FE6A21CADAF.jpeg I know its Ford, take note end of crank rust and odd shape oil pan.
    Any help would be appreciated
  2. 55Deso
    55Deso
    from Wyoming
    The dual sump pan was used in car ch***is(primarily the fox platform) from about '78/79 to '95. Just at a glance I see that your timing cover doesnt have a mechanical fuel pump provision and the pan has an oil level sending unit bung so you likely have an engine manufactured/originally installed in something post 1986, although there are a few exceptions.
  3. oldrelics
    oldrelics
    from Calgary
    Do you think its a 302 ci?
  4. George
    George
    probably, but you need to know if it has the 302 or 351 firing order....
  5. R Pope
    R Pope
    302 0r 351W. Can't tell more from your pics.
  6. Deuces
    Deuces
    Take a picture of the distributor hole and the front China wall and post the picture......
  7. oldrelics
    oldrelics
    from Calgary
  8. Deuces
    Deuces
    87-88 351W powered Crown Vic used a similar oil pan.... I have one in my 91 pony..... :oops::D
    Yours is probably a 302....
  9. saltflats
    saltflats
    from Missouri
    Judging by the end of the crank you will get a chance to find out what it is.
    Hnstray likes this.
  10. Jalopy Joker
    Jalopy Joker
    do you have numbers from side & rear of block?
  11. squirrel
    302, the block is way too short to be a 351, isnt' it?
    LM14 and Deuces like this.
  12. Deuces
    Deuces
  13. greybeard360
    greybeard360
    302 and 351W are same length. Deck is taller, intake wider. Need to see the intake to tell.
    302 HO carb motors used a 351W 4bbl camshaft, that is the reason some 302's had the 351 firing order.
    Deuces likes this.
  14. LM14
    LM14
    from Iowa
    If the top of the deck is even with the top of the water pump right in front of the head it's a 302/5.0. If there is about an inch between the top of the water pump and the deck it's a 351W/5.8.
    Looks too short, it's either a 302/5.0 or worse a 255. Look like a 302/5.0 from the outside.
    SPark
    Deuces likes this.
