Engine identification, quick help needed!
Discussion in 'The Hokey Ass Message Board' started by Florian, Jul 16, 2009.
  1. Florian
    Florian
    Hi!
    Could buy a V8 engine for cheap. Seller doesn´t know very much about the motor.
    He says that it is a 4.8l V8 engine with ca. 390 HP. The engine number is: D4DE-6015-BA 5L6
    Does anyone know anything more about this engine? What manufacturer is it etc.?
    Thank you!
    Florian
  2. revkev6
    revkev6
    from ma
    don't know any 292cube v8's that make 390hp factory.
    could be a vortec 4.8l or a 292 Y block.. your not really giving us much to work with here.....
  3. Relic Stew
    Relic Stew
    from Wisconsin
    The casting # is for a 1974 revision Ford 302. Nothing special. Factory stock rating was about 140 hp. 390 hp would require a lot of modification.
  4. havi
    havi
    Do you mean 5.8L? and it would be a mid 70's 351W....certainly not 390hp in stock form.
    302 does sound like a d4de code. November 6th, 1975. Granada
  5. Mark H
    Mark H
    from Scotland
    That's a Ford part no.
    D '70's
    4 1974
    D Maveric line '70-'74,Falcon '60-'69,Granada '75 up
    E Engine
    6015 Part Number
    BA Number of production changes
    5L6 Sorry,don't know
    Hope this helps.
    390 H.P.?
  6. Relic Stew
    Relic Stew
    from Wisconsin
    If it's cheap, it's a decent start for a basic hot rod engine. Plenty of aftermarket for the 302/5.0L.
    Stock, it's a low compression, 2 barrel. Reliable, but not too exciting.
    5L6 is a casting date code.
    5 is the year, 1975
    L is the month. I believe they skipped I to avoid confusion with 1, so November
    6 is the day
  7. Florian
    Florian
    Thanks for your replies so far!
    What is it now? A 292cui Y-Block or a 302cui Windsor? Seller says 4.8l. 292cui=4.785l and 302cui=4.948l
    The vendor sells the engine for some other guy and doesn´t know more about it. Will try to contact the real owner.
    Thank you!
  8. REM/Mo
    REM/Mo
    from Missouri
    It's definitely not a Y-block with that casting no. on it.
    As others have said it is 1974 or later with D4DE on it.
  9. Florian
    Florian
    Okay thanks!
    Seller sent me two pics:
    The deal includes the engine as pictured, transmission and the radiator.
    What do you guys think?
    Florian
  10. Florian
    Florian
    Are there parts availible for this engine to make it look more traditional? Availibility?
  11. I guess it really comes down to how much "Cheep" is. A couple hundred is cheep. $700 and up isn't cheep, especially if the seller can't give you more definite information.
  12. Florian
    Florian
    Topic can be closed. Engine has been sold to another guy.
    Anyhow, thanks for your help guys!
  13. For the sake of conversation, what was the Cheap price?
  14. Larry T
    Larry T
    Cobra valve covers are about 1965, Holley about the same. 221 (same series as 289,302) came out in 62 (I think) so.......you're not gonna get 50's traditional out of it.
    Larry T
