Hot Rods Engine Identification
Discussion in 'The Hokey Ass Message Board' started by Cowtown, Sep 18, 2026 at 12:10 PM.
Tags:
  1. 327 or 350
    2 vote(s)
    100.0%
  2. 302
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Cowtown
    Cowtown
    Can anyone tell me what engine I have? Its a small block GM. Casting numbers on rear of block are 23GM then 3970010 and on the front pad is Z161967 VO42OTJC Thanks For Your Help
  2. deucemac
    deucemac
    010 blocks were all 350, 511 and 815( I believe that's the castig number) were 400s. I am building a 511 at this time.
  3. Nacifan
    Nacifan
    3970010 blocks are almost aways 350.
    Some are 2 bolt main but most are 4 bolt mains. Some even came with a steel crank instead of a cast crank. Many are also high nickel cast iron
    tractorguy and Just Gary like this.
  4. Shows up as 1973 pickup for the TJC suffix code, on initial search.
    tractorguy and 67drake like this.
  5. Fordors
    Fordors
    The only high nickel/high tin SBC blocks from GM were some over the counter race blocks, no production engines came with a different metallurgical content. If someone tries to sell you one based on numbers cast in the timing chain area keep your money in your pocket.
  6. DDDenny
    Well, it ain't a 302!
    tractorguy and Budget36 like this.
  7. Budget36
    Budget36
    But, maybe from a Corvette;)
  8. SS327
    SS327
    Probably from a truck being the 3 letter code starts with a T.
  9. squirrel
    it's a truck engine, and the truck was built at Fremont California
    I wonder what the other two characters are on the partial VIN? it should also have C3 before the Z?
    41 GMC K-18 likes this.
  10. Mr48chev
    Now the fun part, depending on the crank and pistons combination you can make it into a 302 or 327 if you wanted to spend the money. It will cost a lot more than just building it back with 350 parts but you can have bubba factor bragging points for your effort.
  11. jimmy six
    jimmy six
    Block don’t know crank it’s got. Bore it .030” put in a **** 3.875” crank in it and it’s a 395.4 …You tell all your buddies it’s a 396 and f**k with them when you open the hood!
    osage orange and ffr1222k like this.
  12. JD Miller
    JD Miller
    If its stock bore , not bored, and a '73 cast, its probably a nice block . Oil stick on drivers and not a lightweight thin casting like the later year castings
  13. gimpyshotrods
    gimpyshotrods
    Nope. There are no high nickel OEM production GM blocks.
    It's a myth.
  14. Anders W
    Anders W
    I have one 3970010, it is a 350 cu in 2 main bolt 140 hp from a 1973 Monte Carlo.
    gimpyshotrods likes this.
  15. gimpyshotrods
    gimpyshotrods
    Or you can just say you did.
    51504bat, Algoma56 and X-cpe like this.
