engine leveling
Discussion in 'The Hokey Ass Message Board' started by rustypipes, Dec 6, 2009.
  1. rustypipes
    rustypipes
    from san jose
    I know u throw a level on a 4bbl intake to set up ur engine. My question is I set my engine up with a 4bbl manifold with the degree built in to it so carb is level and engine bout 3 degrees down.
    But when I put on my edelbrock X1 6x2 the intake and carbs arent level on that intake. They are going down with the engine angle
    This normal or going to be a problem?
    Thanks
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I dont think it should cause a problem .Im just thinking about boat carbs ,there not ever level 3 degrees I don't think will cause you a problem.......
  3. squirrel
    you gotta jack up the back end of the car enough to get the carbs level
  4. when you go up or down a hill it'll all work out
  5. squirrel
    the blower on my car makes the carbs sit at an angle too...never had any problems with it that I could blame on that.
  6. duste01
    duste01
    make sure your driveline angles are good.
  7. BISHOP
    BISHOP
    make a carb spacer that will take the angle away. just for looks
  8. rustypipes
    rustypipes
    from san jose
    Thanks for the help, Even though i dont like it I can deal with the look. I just wasnt sure if a few degrees would be enough to worry about floats etc on the strombergs
  9. Ruiner
    Ruiner
    Adjust your floats and you'll be good...
