Technical Engine lift plate & lift point examples
Discussion in 'The Hokey Ass Message Board' started by atch, Jun 9, 2023.
  1. atch
    atch
    If there's a similar post, please tell me. I searched and couldn't find anything.
    Over the years I've saved several engine lift apparatus pictures. Here are some of them. Please add yours.
    For FLATHEAD FORDS & MERCURIES (I know @Mart made #3. If you made one of these please step up and take credit):
    KR Wilson (or possibly copy of same) flathead lifting tool:
    egads, Deuces, uncle buck and 2 others like this.
  2. atch
    atch
    Random:
    rod1, egads, ronzmtrwrx and 4 others like this.
  3. atch
    atch
    egads and Deuces like this.
  4. I use those soft slings, saves scratching stuff up. Sometimes I will use chains, but tie a sling under the mill, just in case.
  5. atch
    atch
    b-t-w; I used to collect factory lifting point brackets from the salvage yards when I used to hang out there more often. A while back I sandblasted and painted them. Please ignore all the miscellaneous stuff in the background.
    egads likes this.
  6. nochop
    nochop
    from norcal
    Don’t scratch the valve covers IMG_4500.jpeg 66629180126__F435CCC5-189E-45D6-8102-0DF6E645D0E7.jpeg
    rod1 and Deuces like this.
  7. choptop40
    choptop40
    Tow style strap , seat belts ….works well around exhaust on a v8 and wont damage tin .. i use seat belts pirated from junked cars to lift motors..
    bobss396, Deuces and nochop like this.
  8. uncle buck
    uncle buck
    I see some great examples!
  9. bobss396
    bobss396
    In the 'yards, I have used heavy duty fan belts and a wrecker boom.
    RMR&C likes this.
  10. RMR&C
    RMR&C
    from NW Montana
    The Packard 8 you posted belongs to @bobbytnm I believe
  11. 51504bat
    51504bat
    Although I've done it in the past, always wary of lifting a flathead with straps around the exhaust manifolds. They have been known to break.
  12. ekimneirbo
    ekimneirbo
    from Brooks Ky
    One thing to consider is that when installing OR pulling an engine, one thing that happens when the chains pull toward the center of lift, things like valve covers and distributors sometimes get damaged. By making a lifter that spreads the lifting points to 4 locations (near each corner)there is much less chance of damaging things. Its cheap and easy to use one of those tilting HF lifters and add two welded crossbars to them. It also fits virtually any engine or engine AND transmission combo unlike brackets that tend to work with only one engine and are not adjustable. More versatile ............:D
  13. DDDenny
    With carb.
    Without carb.
  14. Rehpotsirhcj
    Rehpotsirhcj
    I just used an intake gasket as a pattern, seems to work well
    '28phonebooth likes this.
  15. goldmountain
    goldmountain
    I was going to show mine but you beat me to it!
  16. atch
    atch
    So take your well-earned credit; tell us which one is yours.
  17. atch
    atch
    b-t-w; I guess I'm just overly cautious, but I've never trusted (or used) a lift plate attached to an aluminum intake manifold where the carb would otherwise be.
    Has anyone ever had one of these fail and drop your engine?
    LWEL9226 likes this.
  18. leon bee
    leon bee
    My over-riding thought is always like this: I coulda had the engine out and put back in while some of y'all were making those nice devices.
  19. atch
    atch
    @leon bee,
    Great. Show us what you use to lift the engine with.
  20. choptop40
    choptop40
    We used to unbolt eng/trans and flip junkers over to get engines to fall out.. did a few that way..
  21. saltflats
    saltflats
    from Missouri
    Mike, did seeing my charm bracelet hanging on my engine hoist get you thinking. :D
  22. atch
    atch
    Hold it just a minute there cowboy. You accusin' me of thinkin'?
    saltflats likes this.
  23. ronzmtrwrx
    ronzmtrwrx
    That gold Flathead is mine.
    rod1 likes this.
  24. atch
    atch
    @ronzmtrwrx,
    That thing is way beyond nice. I'm really impressed.
  25. ronzmtrwrx
    ronzmtrwrx
    Well thank you, man. Bad news is it’s still not put together yet. :cool:
  26. atch
    atch
    That gold flathead could be on display in a jewelry store.
    rod1 likes this.
