engine locks when starting
Discussion in 'The Hokey Ass Message Board' started by chainsaw, Oct 29, 2011.
  1. chainsaw
    chainsaw
    350 350 combo, when trying to start turns over a couple time the locks up. try it again ,same thing. sounds like something internal locking the engine. I can turn it over by hand fromthe flywheel and it doesnt lock. I cant see any chipped teeth on the starter or flywheel, ran great yesterday , no strange noises. Where do I look from here ? Bad starter or engine ?Thanks
  2. Ghost28
    Ghost28
    loose torque converter bolt? loose starter?
  3. chainsaw
    chainsaw
    Starter and converter bolts tight. I used the converter bolts to turn it over , marked 1 bolt and turned it untill it came around 3 times. hope that made at least 1 revoltion of the engine.
  4. Ghost28
    Ghost28
    You could pull a plug and see if there is any liquid in the cylinders. Does it have an electric fuel pump?
  5. dreracecar
    dreracecar
    from so-cal
    To much advance and bucking up against the timing? If something locks up it stays locked up.
  6. Pull the plugs and crank it.
    One revolution by hand can be deceiving.
    If it cranks without plugs and is not spewing **** out, look at your timing.
  7. noboD
    noboD
    What he said.
  8. fts55
    fts55
    from guthrie ok
    Low battery?
  9. chainsaw
    chainsaw
    Ok, pulled the plugs, all good ,cranked over. Put plugs back in, did the same thing except it got past the lock up and started and ran fine, no weird noises. Turned it off ,restarted, no problem. Off and restarted did it again but started and ran fine. Battery reading 12 45. I didnt check or mess with the timing yet, I'll try that tomorrow. It does sound like that sound the battery makes with a bad connection , only 2 or 3 times louder.
  10. tooljunkie
    tooljunkie
    from manitoba
    dist cap has moisture or tracking-gets worse when damp.seen tis a few times,its like a hydraulic lock.
  11. Yup, too much initial advance and your battery voltage is a little low (should be 13+). Great combination for that problem to occur....
  12. scrap metal 48
    scrap metal 48
    3 guys above are probably correct.. Too much advance.....
  13. 41 C28
    41 C28
  14. justanothergeezer
    justanothergeezer
    from indiana
    moisture, carbon, tracking, all related to timing.
    also have seen this in hi comp engines.
    Glad to hear you got it started.
