1952-59 Ford engine mounts
Discussion in 'Off Topic Hot Rods & Customs' started by bashnaka, Mar 4, 2013.
  1. bashnaka
    bashnaka
    from england
    so i was looking at Butch's swap sell it site for the engine mount kit for fitting the 302 in to a 55 and noticed than the part number for the kit is diferent between the 6 pot and 8 pot engines so is the engine mount cross member not the same ? i have the straight six and am weighing up my options
  2. meknow63
    meknow63
    from SoCal
    I asked this Q a short while back, go to search and engine mounts and you ca find the discussion. Hope this helps.
  3. bashnaka
    bashnaka
    from england
    tried search and cant find it
  4. fordsbyjay
    fordsbyjay
    from Lafayette
    I think the number of holes is different. I have a 6 cyl car and it had 2 holes for the motor mounts and the stud on the 302 mount needs to be right in the middle of the two slots.
    I just modified my mounts to make the groove longer.
    Then I used fox body mustang mounts. I put a level on the motor to make sure it was level side to side. That was all before I found this group with all the knowledge they have. Swap mounts sound so easy. Buy them. :)
  5. fordsbyjay
    fordsbyjay
    from Lafayette
  6. JeffB2
    JeffB2
    from Phoenix,AZ
  7. fordsbyjay
    fordsbyjay
    from Lafayette
    Really? An $8 motor mount is not very good quality? lmao
