Technical Engine Paint Color
Discussion in 'The Hokey Ass Message Board' started by $um Fun, Mar 16, 2019.
  1. $um Fun
    $um Fun
    from Nor Cal
    I really like the color of the Blitzen benz race car motor and would like to duplicate close as possible the engine color blitzen-benz-motor.jpg for my Model A motor. It almost looks like a Pontiac color. Any ideas would be helpful .
  2. oldiron 440
    oldiron 440
    To me it looks gray.
  3. Fortunateson
    Fortunateson
    Looks like the grey that Chevy had in the forties.
    302GMC likes this.
  4. Deuces
    Deuces
    Blue-ish grey.......
  5. $um Fun
    $um Fun
    from Nor Cal
    I saw it in person and its blue - ish grey. I thought Pontiac had a color like that, but I might be mistaken. Just like to get close with the color. Any cars used a blue - grey engine paint?
  6. rudestude
    rudestude
    They have these things they call paint color charts...for all models of cars ,trucks, engines, do a search...this one here is engine paint colors but when I down loaded it just the colors came through not the text... 15527797975126142490107055507008.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  7. rudestude
    rudestude
  8. wvenfield
    wvenfield
    Pontiac does look a little bluer than that.
  9. Black_Sheep
    Black_Sheep
  10. Go to your local paint distributor. They have chip decks. Find the color you think is closest and have them mix it.
  11. Deuces
    Deuces
    Last row down, second from the left... ;)
  12. tb33anda3rd
    tb33anda3rd
  13. stuart in mn
    stuart in mn
  14. rudestude
    rudestude
    It's Daimler-Benz AG,of Germany , engine blue epoxy or after the merger with Chrysler, it's now Daimler-Chrysler AG engine blue enamal...
  15. $um Fun
    $um Fun
    from Nor Cal
    Thanks for all the tips! I was hoping to find something close out of a rattle can engine paint. Looks like I will get mixed and spray it with a gun
  16. Ford Aerostar had a color close to it. Maybe the Regatta Blue #18828
  17. rudestude
    rudestude
    They have all the engine colors in rattle cans.
    Here's something I was just messing around with..it's just enamel engine color model paints that are brushed on..top right is Chrysler engine blue with just a speck of medium blue mixed in ..
    Below that on the right is Chrysler engine blue straight out of the bottle..
    Bottom left is Chrysler engine blue mixed with a touch of Pontiac engine blue...
    Then the pictures are all the same just each one is a different setting on the tablet camera... 20190316_224625.jpeg 20190316_224623.jpeg 20190316_224621.jpeg 20190316_223606.jpeg
  18. Fortunateson
    Fortunateson
    I got four spray cans pretty well an exact match. I'll try to check who made it tomorrow.
  19. chopolds
    chopolds
    from howell, nj
    You DON'T have to use engine paint! But I'm not sure about using regular paint in a can for an engine. I've had luck with Centari, Single stage Urethane, Imron, and Base/Clear urethane. Spraying it is best, use a hardener in the paint for best results, resistance to spills, abrasion, etc. That's where spray bombs fall short.
    I'd pick a car color, have your local body shop supply mix it in acrylic enamel, and put it in a spray can, if you don't have a spray gun.
  20. $um Fun
    $um Fun
    from Nor Cal
    I was hoping to use engine paint and didn't think the regular paint would hold up to the heat. But reading some of the posts and other threads its seems to work,
  21. I've used regular paint on lots of engines, even candy lacquers. My daily driver small block was painted with spray cans from Lowe's, it's been on there 10 years. It's all in the prep.
