Engine paint!!
Discussion in 'The Hokey Ass Message Board' started by 54hotrodder, May 30, 2012.
  1. 40FordGuy
    40FordGuy
    I brushed POR 15 Ford Green paint on my flattie..... Still looking good.
    I like the shop that hot tanks after machining....removed any remaining "trash" from the machining process.
    4TTRUK
  2. redlinetoys
    redlinetoys
    from Midwest
    Just an FYI, I have had good results, in fact very good results with standard color high heat engine paint in spray cans... However, I tried using high heat clear over a silver basecoat several times and found that the clear ambers and turns kind of a gold/green tint pretty quickly. I would NOT use clear over a lighter color again. Probably way better to just use base/clear auto paint instead.
  3. 54hotrodder
    54hotrodder
    I have heard of that happening with the clear coats on motors
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    the engine in my A is painted with single stage enamel with metalic flakes..nothin fancy no high heat shit..
    the engine doesnt get much over 210..most coatings can stand that..
    some engines where the exhaust ports protrude from the head, may show some scorching..
    think of it this way..its a water cooled engine..so the point of the coolant is for the engine not to get blistering hot
